Will this testpipe replace my factory cat WITHOUT modification
Old Aug 10, 2012 | 08:58 PM
Vagitarian's Avatar
Default Will this testpipe replace my factory cat WITHOUT modification
http://www.ebay.com/itm/T304-STAINLE...item27c2b2f650
I dont need to worry about emissions. And Im making an order from this company on ebay and they sell a test pipe that appears to be quality, Im just curious if the thing will drop in and fit in the stock location on a stock Crx with stock exhaust and header. Just out of curiousity if it would actually help me out, quick comparisn of how much the stock catalytic is holding me back I guess. I'll probably switch back shortly if the smell is bad, as this is my daily, more of a ***** and giggles thing so I dont want to have to modify my exhaust or flanges to make this pipe work.
It says it is 2.25" but the flanges appear to be the same as my stock exhaust.
Will in bolt in place with very little to no mods...
Old Aug 11, 2012 | 04:12 PM
Vagitarian's Avatar
Default Re: Will this testpipe replace my factory cat WITHOUT modification
bump
Old Aug 11, 2012 | 09:47 PM
dc5itracer's Avatar
Get a adjustable test pipe from plm and Ill buy your stock cat
Old Aug 12, 2012 | 06:18 AM
Vagitarian's Avatar
didnt answer my question at all
Old Aug 12, 2012 | 06:24 AM
M-benz's Avatar
Lol
Old Aug 12, 2012 | 04:50 PM
Vagitarian's Avatar
anybody?
Old Aug 12, 2012 | 04:52 PM
sstupid's Avatar
10 Year Member
Originally Posted by Vagitarian
anybody?
Sure, I'll buy your old cat.
Old Aug 12, 2012 | 06:48 PM
BLU CIVIC's Avatar
Track Advocate
not worth doing especially with stock exhaust system. on;y thing you'll achieve is an increase in noise and emissions. will that fit? i dunno
Old Aug 13, 2012 | 01:05 PM
Vagitarian's Avatar
Its a Ef7 exhaust so its 2" ID I believe, I just wanna try it for fun I guess, butt dyno
Just wanna be sure it will fit without modification
Old Aug 13, 2012 | 01:36 PM
JDpower's Avatar
Idk if it would fit but pointless like he said it'll get u 2-4 hp at most, and pollute more.
Old Aug 13, 2012 | 07:26 PM
Vagitarian's Avatar
whats wrong with 2-4hp?? Im also unsure of the condition of my factory cat.
I just wanna try it, stop thinking so much on how to turn the idea down.
I was just hoping if someone knew if that was the correct looking orientation/flanges etc and if anyone used one with success of fitment and swappability etc
Old Aug 13, 2012 | 07:38 PM
.Manny.'s Avatar
Touching My Member
PM whtgf. I think she used the exact one. Hit her up.
Old Aug 13, 2012 | 07:41 PM
Hidenplanvew's Avatar
Its closer to 1 to 2 hp as there shouldpnt be more the 1 to 2psi of back pressure unless your cat has failed... You wont even feel a diffrence, in your mind you will but you wont be any faster.. They also have a rattle when you take a cat off with a stock exhaust that sounds like crap.
Old Aug 13, 2012 | 08:06 PM
whtgf's Avatar
exwhtgf
you troll!
Old Aug 14, 2012 | 10:06 AM
Vagitarian's Avatar
did you not use this one whtgf?
Old Aug 14, 2012 | 01:08 PM
LudeEFv2.4's Avatar
My old title sucked.
Looks like the rite size, but I don't have it here in front of me so there's no way of knowing for sure or giving you an accurate answer.
Old Aug 14, 2012 | 05:22 PM
Vagitarian's Avatar
The seller says the pipe is 16.75" long, is that the size of the factory cat?
heyimjarid
Jun 28, 2011 04:59 PM
davidluko
Feb 24, 2009 07:25 PM
allmotrDC2
Nov 16, 2005 01:58 PM
07
Apr 5, 2004 09:55 PM
fredtoast
Feb 11, 2003 01:32 PM
