I NEED HELP - Coilovers and Camber Kits
I just bought Function and Form Type 1 Coilovers for my car.
Everything is normal for them.. Blah blah blah.
I need to know what a good camber kit I can buy so I can maximize the usage of these bad boys.
Please let me know. I need help soon.
Depending on how low you go you will probably be between 2-3 degrees of negative camber in the front with stock upper control arms. With 16 inch wheels, 205/50/16's and the tire about a centimeter tucked into the fenders I'm at 2.4 degrees. You don't NEED camber kits if you don't want to buy them, assuming you're not just trying to slam the **** out of your car. If you really want them though I would go with Hardrace, or possibly Buddy Club. Stay away from BLOX, Skunk2, etc. My friend had Skunk2 camber kits up front and the ball joint boots tore open in like a week. Sold them to go back to OEM control arms. Also be sure to check your clearance between your tire and the pinch welds in the wheel well after you install your suspension. I had a brand new tire hacked up by those. Had to hammer them flat. Hope this helps.
you dont really need a camber kit unless your wheels are REALLY poking out. unless you like that. but people usually get a camber kit to tuck their low *** offset wheels beheind the fender. other than that, just get an alignment and youre good.
diznikkajebus
28
Apr 2, 2009 04:42 PM
joostan
Dec 7, 2005 05:08 AM
