Integra Part Out/Turbo kit/Suspension/Brakes/Body parts
Contact: Call/text 540-359-0106
Descriptions/Pricing:
Turbonetics Kit: was $1100 lowered to $1000 and I will include the Moroso oil pan so you don't have to worry about fabbing up the drain for your oil pan.
Turbonetics Turbo Manifold
Turbonetics Evolution Wastegate has an 8psi spring in it and will come with an extra 3psi spring
Open dump tube
Turbonetics T3 Turbo
3" Downpipe wrapped in titanium heat wrap
All of the charge piping
Spearco intercooler
Turbonetics Evolution blow off valve
Stainless oil feed line
-10AN oil drain line
Precision 550cc injectors
Plug&play OBD2 injector clips so you don't need to solder in new clips
PTuning vacuum block
Autometer boost gauge
Pictures:
http://s416.photobucket.com/albums/p...Integra/turbo/
Moroso baffled oil pan: $150
Moroso baffled oil pan with an added -10AN bung welded on. Also has two 1/2NPT holes for oil temp sensor or alternative drain bungs.
Koni/Ground Control: $500
Koni Yellow Struts, Ground Control coil over sleeves, and Eibach springs. Strut and sleeves have about 20k miles on them. I just bought a brand new full set of springs that have about 300 miles on them. Will also include the softer set of OTS springs with sale.
Instrument cluster bezel two-gauge pod: $30
Bezel holds one gauge in each lower corner of instrument cluster.
Hard Race Rear Lower Control Arms: $50
Were installed with the coil overs. 20k miles.
ITR rear sway bar with Beak's reinforcement kit: $100
OEM ITR rear sway bar. Installed about 2k miles after the coil overs. By far the best improvement to this car's handling.
OEM ITR front strut bar: $60
ITR Front brake upgrade: $200
ITR front brake calipers, Carbotech pads(basically brand new), Mini Cooper Rotors. Inlcudes knuckles. Will come with 4 new in box rotors. I always took spares to the track with me so they can go with the rest of the setup.
98-01 4040 Proportioning Valve and lines: $50
Includes the valve and brake lines to the front brakes that are required to remove the abs from 98-01 Integras.
Carbon Fiber(looking?) air bag delete tray: $25
Subframe and steering rack: $150
Entire subframe assembly with steering rack and hardware. Outer-tie rod ends replaced less than 1k miles ago.
Body Parts: body panels are frost white
Headlights: $150. Perfect condition, no broken tabs, very clear. Includes bulbs with connectors.
Hood:$100
Front amber turn signals: $20. Includes bulbs with connectors.
4-door all red tail lights: $100. Includes bulbs with connectors.
Trunk with Gs-R spoiler: $100
Doors(complete): $100each.
Front bumper cross beam: $40
Sunroof motor and glass assembly:$100
Black dash: $75. Had three gauge pods screwed into the center of it.
Black Steering wheel with air bag: $50
I think that is most of it. If I think of or find more stuff laying around I will update this post. All prices are OBO within reason.
Thanks for looking.
Open dump tube
Spearco intercooler
Pictures:
Hood:$100
Thanks for looking.
Interested in the 40/40 Proportioning valve for ABS delete with ITR Swaybar and beaks bar and possible control arms. 2024468935 CASH IN HAND
jeezyskillz
Jan 25, 2007 10:16 PM
