bc spec 4 cams
Old Aug 10, 2012 | 05:03 PM
dc2br's Avatar
Default bc spec 4 cams
hey i currently own a jdm honda integra type r x and just wondering do any of you guys run buddyclub spec 4 cams on your motor?what improvements did they give and what do i need to run them?higher compression e.t.c
Old Aug 10, 2012 | 05:21 PM
luvmihatch's Avatar
Default Re: bc spec 4 cams
Google is your best friend.
But back to topic, there are many different reviews, thats a pretty agressive cam. The head will need to be built at very least.
Here is a review I found:
http://www.ek9.org/forum/engine/122-...ts-review.html
and this is the google selection:
http://www.google.com/#hl=en&safe=of...w=1283&bih=680
Enjoy.
Old Aug 11, 2012 | 06:40 AM
dc2br's Avatar
Thanks for that will i need to run higher compression pistons?
Old Aug 11, 2012 | 08:54 AM
HYREV2NR's Avatar
A higher C/R always compliments aggressive cams but if the head hasn't had any PNP work it will bottle neck in high RPM's for sure. A cam as big as you're referring to will not be very drivable on the street and all low end torque will go out the window.
slowpokecivic
Nov 10, 2006 03:07 PM
ZenkaiRacer
Sep 29, 2006 11:08 PM
tomlinson619
May 22, 2006 07:59 PM
jdmcx
Dec 21, 2003 06:34 AM
spoonitr529
Sep 8, 2003 09:20 PM
