96 Civic DX - Can't get the dome light working for the life of me
Old Aug 10, 2012 | 04:16 PM
jodyboy's Avatar
Default 96 Civic DX - Can't get the dome light working for the life of me
Ok so I've gone to hell and back (not really) to get my dome light working. Replaced the housing, replaced the bulb, tried everything.
There are 2 wires, a green/red and a white/red. When the dome light is set to "on" they both read about .55 volts. So I imagine that the wires and housing are working correctly.
I know that your dome light can mess up if you install an aftermarket radio but I'm fairly certain thats only for the "door" option, not for the "on."
Any help would be greatly appreciated.
Old Aug 10, 2012 | 05:00 PM
Former User's Avatar
Default Re: Can't get the dome light working for the life of me
In your first post, you MUST provide all pertinent information about your car and engine.
Old Aug 10, 2012 | 05:45 PM
jodyboy's Avatar
1996 Honda Civic DX
4cyl 1.6
Old Aug 10, 2012 | 07:44 PM
GnrlKll's Avatar
If an aftermarket radio has been installed and the factory radio was completely removed, you wont have a dome light. There are three connectors for the factory radio. One for the radio, one for the security, and the other is for the dome light and possibly other accessories. Not entirely sure. But I have tested this as I still have the factory radio, behind the dash.
Old Aug 11, 2012 | 06:05 AM
jodyboy's Avatar
That can't be true. Mine used to work after I put my radio in and I know someone who still has it working.
Even if it was the case with mine, how can there still be voltage coming through the wires?
Old Aug 11, 2012 | 06:24 AM
Only Civics with the keyless feature would be affected by swapping out the stock radio. The DX does not have keyless.
The Wht/Red wire at the dome light should read battery voltage (~12V) with the dome light off. What is the "off" voltage?
Also measure voltage to body ground at both top test tabs of 7.5A hood fuse 43. Click the Fuses link in my signature. Post the two voltage readings at each tab.
Old Aug 11, 2012 | 10:03 AM
jodyboy's Avatar
Default Re: 96 Civic DX - Can't get the dome light working for the life of me
Wow I feel like such an idiot haha... I didn't even know there was a fuse for it. I checked under the dash but didn't find one. That seems weird it would be under the hood. But I changed the fuse and it works thanks
deving916
Feb 9, 2012 05:55 PM
Php
Feb 20, 2010 08:14 PM
runtohell121
Lighting
15
Dec 2, 2009 11:23 PM
goatboy
Sep 22, 2004 09:42 PM
