motor oil in transmission?
Old Aug 10, 2012 | 01:58 PM
GPC91's Avatar
Default motor oil in transmission?
i was looking for what type of transmission fluid to put in my car and it came to a like on here that people said they used 10w-30 motor oil in there trans. this doesnt sound right to me but im curious if it works since i have lots of oil since my dad buys it in cases. so it would save me from making a trip to get tranny fluid. so just looking for opinions on that. thanks
Old Aug 10, 2012 | 02:41 PM
ryanevansoh's Avatar
Default Re: motor oil in transmission?
Yes you can use that. That's what Honda suggests using, or there manual transmission fluid. 10w-30 worked fine in my ef
Old Aug 10, 2012 | 03:16 PM
zrickety's Avatar
The manual recommends motor oil. I use castrol GTX. 10w30 or 10w40 if you live in a hot climate.
Old Aug 10, 2012 | 04:54 PM
90civic-ZC's Avatar
Like they said, just to throw in my two cents while i wait for my tall glass of cooled genuine draft of Bud Light, I use GM synchro mesh friction......(I believe it's called). You can only get it from a GM dealership but it's the ****. Probably unnecessary......yes, a little expensive.......yes. I think it's Castrol that makes a very similar product as well.
Old Aug 10, 2012 | 05:39 PM
KINGVEM^^ED6's Avatar
While I eat my pizza
I ran motor oil for a few days until I got some
Honda mtf.....if I were u id run that it took away my grind in 3rD
Old Aug 10, 2012 | 05:53 PM
BiG ChOr!Zo's Avatar
10w30 conventional
Old Aug 10, 2012 | 05:58 PM
.Manny.'s Avatar
Touching My Member
I use 1qt Synchromesh/1qt Honda MTF. Pretty much all that **** works.
I found that combo to "feel" best for my transmission. Yours might like conventional oil best.
Old Aug 10, 2012 | 07:31 PM
Hidenplanvew's Avatar
Honda MTF, it has better wear protection and I think they still use zink in the mtf too
Old Aug 11, 2012 | 12:44 PM
GPC91's Avatar
well alright then. just curious. what about 5w30 instead of 10w30? will they both work?
Old Aug 11, 2012 | 12:51 PM
M-benz's Avatar
I used 10w30 in my trans. too.
Old Aug 11, 2012 | 02:19 PM
Ju_S12_Turbo's Avatar
I used Delo 15-45 in my trans, never ran into any problems with it.
Old Aug 11, 2012 | 05:25 PM
Perfectionist's Avatar
Originally Posted by GPC91
i i have lots of oil since my dad buys it in cases.
LOL
10W30 is fine and what was originally spec'd.
I switched to Honda MTF and thought it made enough of an improvement to warrant the extra cost.
Old Aug 11, 2012 | 08:02 PM
GPC91's Avatar
alright well i just put in a trans that hasnt been used in 3 to 5 years so i guess i will run oil for a couple hundred miles then switch over to mtf fluid.
GSR_hatch936
36
Nov 12, 2007 08:53 PM
MrEg
38
Sep 16, 2003 06:52 PM
wizzards581
12
Mar 6, 2003 11:15 AM
216.226.142.95:27016
Feb 20, 2003 07:19 PM
Mikey
Oct 5, 2002 04:14 PM
