B16 "chugging" when accelerating
Old Aug 10, 2012 | 01:47 PM
GT500FTW's Avatar
Default B16 "chugging" when accelerating
Just finished my engine transplant into another car and took it out for a test.
After a minute of driving, the car will not accelerate. If I put my foot on the accelerator, it might rev up to 2-3k, but no higher. If I put my foot right down, the revs get lower and the car wants to cut out. It starts to splutter and backfire!
It's even worse trying to go uphill.
I have an aftermarket fuel tank, filter, Walbro fuel pump
I have new ht leads, spark plugs etc
Also noticed that when I press the brake or turn on the lights, the revs drop. it might be related.
Any ideas?
Old Aug 10, 2012 | 02:10 PM
EJ8_Man's Avatar
Default Re: B16 "chugging" when accelerating
Is the timing correct?
Old Aug 10, 2012 | 02:16 PM
Swap'DShuttle's Avatar
Any codes? Sounds like it could be map sensor related or vacuum problems. Also sounds like you are in limp mode.
Old Aug 10, 2012 | 02:55 PM
GT500FTW's Avatar
Timing is fine. Not been touched since it was taken out the other car.
I don't think it was in limp mode. If I ease the throttle open, it slowly revs up. If I turn the car off and on again, it seems to get a bit better for a few seconds.
No codes. No CEL
Old Aug 10, 2012 | 06:13 PM
jmotley's Avatar
i had an ep3 with the same symptoms once, it was all factory.. the problem ended up coming from a "clogged up" cat.
Old Aug 10, 2012 | 11:50 PM
What wiring if any had to be done for the swap?
Old Aug 11, 2012 | 05:05 AM
GT500FTW's Avatar
Full loom swap from donor car. The car seemed fine when revving up in neutral.
Doesn't have a cat.
Old Aug 11, 2012 | 05:15 AM
lazlong's Avatar
Inspect the trottlebody and see if your fuel pressure is correct. Also look for pinched wires.
Old Aug 13, 2012 | 06:41 AM
kyden's Avatar
do you have the map and tps plugs mixed up?
Old Aug 13, 2012 | 12:06 PM
GT500FTW's Avatar
I'll check all of these things.
Think it could be fuel starvation. The fuel could be sloshing to the back of the alloy tank, and not reaching the external pump.
Gonna triple check the basics....vacuum lines, earths, sensors etc...
Old Aug 15, 2012 | 01:54 PM
GT500FTW's Avatar
I checked all of these things.
Tps and map are correct
Checked for vacuum leaks and kinked wires.
Throttle body is fine.
Fitted a swirl pot, so it's not fuel starvation.
Fitted a new fpr.
It seems fine for the first few minutes, but then the problem starts - low idle, and almost stalling when I press the throttle.
I disconnected the lambda sensor and got a CEL, but the idle got better and the car revved up to about 5.5k rpm.
Any ideas?
Old Aug 16, 2012 | 03:51 PM
GT500FTW's Avatar
Could incorrect ignition timing cause this? I moved the distributor a few month ago.....could the timing being slightly too advanced/retarded cause this?
Old Sep 4, 2012 | 12:26 PM
GT500FTW's Avatar
Still having trouble with this.
I have redone the ignition timing, changed the engine loom, and distributor.
After a minute of driving, the car does not want to rev past 4k rpm.
The really strange thing is that when I turn the engine off, then on again, it's fine again for another minute, but then the problem starts again.
Getting pretty pissed off with this problem now.
No cel.
As its a JDM car, the exhaust temp sensor light is on, but that was on before the swap.
Any advice?
Old Sep 4, 2012 | 05:51 PM
lazlong's Avatar
May be a bad sensor (lambda sensor) or clogged catalytic converter
gooblinn258
Dec 17, 2013 08:58 PM
TimKennard
Jan 2, 2011 10:04 AM
gringo7718
Dec 20, 2008 09:06 AM
Powered By Garrett
23
Feb 17, 2007 12:47 PM
b16_madman
Jul 1, 2003 08:48 PM
