radiator fan to OEM relay? - wiring help
Old Aug 10, 2012 | 07:39 AM
ApexiChild's Avatar
Default radiator fan to OEM relay? - wiring help
For some reason my fan won't turn on by itself (when car get's hot).
I wanted to know how to "re-wire' the fan from the THERMO sensor to ECU to RELAY.
I don't know which wire does what or goes where.
please help.
Old Aug 10, 2012 | 11:55 AM
ef92b's Avatar
Default Re: radiator fan to OEM relay? - wiring help
From Helm's repair manual but labeled with OBD-1 ECU connections
hth
Old Aug 10, 2012 | 12:56 PM
KINGVEM^^ED6's Avatar
Check yellow wire on ignition switch
Under steeting colum
My fan wouldn't turn on and yellow wire was cracked
Fixed it n now works fine
Old Aug 12, 2012 | 06:52 AM
ApexiChild's Avatar
thanks fellas
Old Aug 12, 2012 | 10:41 AM
sstupid's Avatar
10 Year Member
Check the famous G101 ground at the water neck on the back of the motor. That ground point is downright famous for a reason.
Old Aug 18, 2012 | 08:12 PM
heli_ebook's Avatar
I might be doing it: see Here I am not blowing a wad on a 2o yr. old ECU!
Wytas
Oct 16, 2017 01:44 PM
meanTheDope
21
Aug 24, 2016 09:20 AM
clean_sol93
Dec 11, 2011 08:39 AM
maverick32
Jun 17, 2009 10:49 PM
jDMJeRk
May 4, 2005 07:43 PM
