help with d16y7 rough idle
Old Aug 9, 2012 | 08:11 PM
jlbarrios's Avatar
Icon7 help with d16y7 rough idle
alright so i already replaced iacv sensor and the coolant temp sensor the one under the dizzy so what else could it be any help will help
Old Aug 9, 2012 | 08:26 PM
Hondaciv866's Avatar
Default Re: help with d16y7 rough idel.
any cel lights on? you can always give your car a round of seafoam cleaning and see if that helps
Old Aug 9, 2012 | 09:17 PM
jlbarrios's Avatar
yea it is throwing a cel ill look nd post them tomorrow .
Old Aug 10, 2012 | 09:13 AM
jlbarrios's Avatar
codes it is throwing p1509 iac valve circut failure
and p0135 a/f sensor1 heater system malfuntion
Old Aug 10, 2012 | 09:46 AM
Former User's Avatar
Default Re: help with d16y7 rough idle
Reset the ECU and then check whether either of the codes repeats. Post any code that repeats.
Also give a more detailed description of the rough idle.
Old Aug 10, 2012 | 04:37 PM
jlbarrios's Avatar
Alright I will do that
Old Aug 13, 2012 | 01:36 PM
jlbarrios's Avatar
Alright I reset the ecu and they both came back I'm gana replace the o 2 sensor now
Old Aug 13, 2012 | 01:40 PM
Don't just replace parts, do some electrical tests to pinpoint the problems.
What car?
Is 7.5A dash fuse 15 blown?
What's the resistance of the O2 sensor heater element? Does it get voltage?
Is the IACV plugged in? Does its plug get voltage?
Old Aug 13, 2012 | 02:44 PM
jlbarrios's Avatar
Alright I'm gana go buy a test tool to test all the above
solex
Honda Civic (2001 - 2005)
Jun 15, 2015 06:02 AM
dragon_lowrider
Sep 22, 2010 10:55 PM
higgunscrx
Apr 15, 2008 12:28 PM
vtecgsr98
Apr 2, 2005 01:24 PM
clean
Oct 8, 2001 04:20 PM
