Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
Car is hard to shift
Old Aug 9, 2012 | 05:29 PM
Bruce Banner's Avatar
Default Car is hard to shift
Recently my 04 TL 6MT has gotten hard to shift.
The gears used to slide right in, up till a couple of week ago, but recently it's been nothcy going into gears and sometimes it doesn't let me in.
1st to 2nd has been really notchy getting into.
Sometimes 5th wont go into 6th, it'll stop me in the neutral position.
4th to 5th was sliding right in EASY, not it's getting a bit notchy.
MTF is 6 months old, honda fluid.
Is this a clutch issue somewhere?
Old Aug 10, 2012 | 09:49 AM
egcoupe42's Avatar
Default Re: Car is hard to shift
sounds like syncronizers to me
Old Aug 10, 2012 | 03:29 PM
I really hope not, I can't afford any tranny work...
Old Aug 15, 2012 | 08:02 PM
I took it to a shop, they said I need a new clutch.
Old Aug 17, 2012 | 12:50 PM
TL-G's Avatar
did they explain why it was the clutch that was causing the problem?
Old Sep 9, 2012 | 11:41 AM
I didn't ask why, I did get the clutch swapped out.
Got the car back on Friday. Drove it home and noticed I was still displayed the same symptoms. The new clutch grabs much better, but I did experience some lock out on reverse and 2nd, which is somethings that has gotten more common lately.
Sometimes it feels a bit odd going into second, kinda like it's wiggling in.
I guess the clutch was not the real problem. I'm not sure what to do when a shop recommends the wrong fix...
I don't know much about clutches and flywheels, I asked for the parts back, they look fine to me.
Old Sep 22, 2012 | 04:49 PM
vtak2nr's Avatar
make the shop pay for the proper fix. you paid a repair for nothing
l
Old Sep 29, 2012 | 01:03 PM
94eg!'s Avatar
#1 Super Guy
Loved
Step 1 would be to swap out the trans fluid. NOT a $1000+ clutch. Replace your trans fluid with either new Honda/Acura MTF or General Motors Synchromesh "Friction Modified" version. Both will help the sychros to work better, but the GM stuff lasts much longer. Expect to pay ~$15 per quart and you need 3 total. The Honda stuff is ~$6/qt. This is a common issue with Honda 6MTs. If you didn't know, check out the 3G Forum over on Acurazine.com.
GM SM FM (must say Friction Modified on the bottle)
It's also sold in an AC Delco bottle and part number if the local Chevy dealer can't find the GM part#:
Honda/Acura:
Old Oct 13, 2012 | 06:10 AM
I did synchromesh, it's smoother and has helped a BIT. Yesterday I swapped out the slave clutch cylinder for the check valve delete.
Its much improved, but I 2nd gear still feels odd going in here and there.
The dealer said it's the synchros. Dealer wants like 2.6k parts and labor for it, I'm not paying that. That's a huge portion of the cars value. I'll ride on the GM fluid banaid fix in the meantime.
The shop that did the clutch, that was a lengthy mess I had to deal with them. They are never touching this TL ever again. They scrapped up the bottom of my bumper and that was a mess that took 3 weeks to resolve. Even then it ended up at 50/50 cost. I shouldn't have had to cover any of that, but I wanted to be rid of this shop and move on with my life.
bmoreb18c1
Jul 20, 2013 07:17 PM
junk95civ
Apr 28, 2010 05:54 PM
Racing1353
Dec 15, 2008 05:18 PM
PAID-$$$
Jun 11, 2004 12:50 PM
Chris Benoit
Feb 9, 2004 02:08 PM
