97 civic hatch w/ B18C...bad passanger axle...what axle do I need?
Cruised the forums and couldn't find a solid answer...problem...worn passenger side axle. Mechanic quickly realized stock 97 civic axle wouldn't fit, difference of about 2 inches in length of axle... doesn't know which part to buy. Motor and tranny are JDM B18C (head stamped 96'). Will any 94-01 teg passenger axle work? Or do I need to buy B-series "Swap Axles" from Hasport or Innovative Mounts?
Whats even the point or purpose behind the "Swap Axles" from Hasport or Innovative Mounts? From the few things I could find on forums it sounds like there is some reason modification or special axles are needed because of length when replacing axle on 96-00 civic w/ B18C swap? just dont want to buy teg axle and find out the second time it doesn't fit and spend money or wasted labor! lol.
