my turbo dilemma
im lookig at getting a new turbo and have a 2 turbo's that im looking at buying i can get the agp zeta 3.2 for $600 the best price i have found on the 6262 was $850 both are journal bearing. please feel free to give any advise or input
turbo #1 agp zeta 3.2
Our largest in-house offering that features a fully machined billet aluminum compressor wheel with flow capabilities past 77lbs/min. We build this turbo with the .63 A/R or .82 A/R turbine housing and the turbo will support past 750whp. This turbo has the normal ported shroud 4" inlet just like all the smaller Deltas and Zetas, however the outlet is 2.5" so you will also need to modify your factory hot side charge pipe to adapt to the 2.5" outlet. With our ultra light weight billet compressor wheel, expect full boost around 3800rpm in the .63 and 4100rpm in the .82.
turbo #2 precision 6262
Compressor Cover Compressor Cover T04E (3" In / 2" Out) S Cover (4" In / 2.5" Out) SP Ported Cover(4" In / 2.5" Out)
Bearing Option Bearing Option Journal Bearing Dual Ball Bearing [+$499.00]
Turbine Housing Turbine Housing T3 - 4 Bolt .63 A/R T3 - 4 Bolt .82 A/R T3 - 5 Bolt .63 A/R T3 - 5 Bolt .63 A/R w/ Gate Hole T3 - VBand .63 A/R T3 - VBand .82 A/R V-Band In/Out .82 A/R Mitsu .63 A/R For Manifold External Mitsu .63 A/R For O2 External Mitsu .63 A/R w. Int Gate T4 - VBand .58 A/R T4 - VBand .68 A/R
Description
Precision's 6262 is one of the most popular turbos on the market. This turbo has almost completely replaced the 35R in a section of the community of people looking for 500-700hp. These work great on a bigger displacement 4 cyl & 6 Cyl applications. We've used many of these on EVO, STi, Supra, DSM & Honda builds.
A well build platform can achieve 600whp+ on daily driven setups. This turbo makes BIG Torque & Horsepower!
Specs:
Compressor- BILLET
Wheel Inducer: 62mm
Wheel Exducer: 82mm
Turbine Wheel -
Wheel Inducer: 72mm
Wheel Exducer: 62mm
MY SETUP
head
built b18b head
port polish
supertech dual valve springs
supertech titanium retainers
supertech inconel valves
jg303 cams
1000cc injectors
aem fuel rail
walbro 255 intank
block
stock bore and sleeves
je 9.5:1 pistons
eagle h beam rods
acl rod and main bearigs
turbo kit
ctd fab custom ac friendly top mount
agp 57 trim
ebay intercooler
tial 44mvs with 15psi spring
turboxs rfl bov
exhaust
2.5'' piping
2.5'' magnaflow resonator
2.5'' magnaflow muffler
Description
Specs:
Compressor- BILLET
Wheel Inducer: 62mm
Wheel Exducer: 82mm
Turbine Wheel -
Wheel Inducer: 72mm
Wheel Exducer: 62mm
MY SETUP
head
built b18b head
port polish
jg303 cams
1000cc injectors
aem fuel rail
walbro 255 intank
block
je 9.5:1 pistons
eagle h beam rods
turbo kit
agp 57 trim
ebay intercooler
turboxs rfl bov
exhaust
2.5'' piping
Better than the Precision, I'll say that much. At least AGP is using 7075 aluminum for their compressor wheels. Just don't get duped into how fast the response is based upon rpms. 750whp-capable turbos never reach maximum pressure by 4000rpms, unless you're running over 4 litres.
Yes. A bit better than a precision. those come only as a ball-bearing cartridge, but there are others. Its not as responsive as a GT35R, because of the larger exhaust wheel, but its close.
ABL 2 FLY
Mar 31, 2010 07:36 AM
hks-gst
Jan 29, 2009 05:07 PM
jetlude
Oct 10, 2007 02:14 PM
