Honda CR-V & Element 2WD & 4WD Element & CR-V
Recommendations on after market front/rear sway?
Old Aug 8, 2012 | 09:26 AM
Snafu-Si's Avatar
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
Default Recommendations on after market front/rear sway?
On my 99 CR-V, front doesn't have one of course, and my rear sway the end link is broken, and the sway itself looks like its rusting away and about to turn to ashes. Figure if I have to replace the rear anyway, I'd do it with something more stout because I can't stand how flexy wexy the car feels at times.
Old Aug 8, 2012 | 09:28 AM
TypeRfit's Avatar
RESIDENT
Default Re: Recommendations on after market front/rear sway?
Personally I have used suspension techniques on 3 different cars and never had one issue. Bushings were good, endlinks were all good quality.
Old Aug 8, 2012 | 11:00 AM
qwrty's Avatar
you dont have a front sway bar on your 99V?? i have 3 99 too all have the front sway bar and their
"meaty" i think 24mm?? but the rear is kinda thin.... i did use addco rear sway bar a good replacement
and its bolt on.. not much of modding needed, i was messing aroung w/ a spare suspension techniques
from my civic at one time and it does need some fabbing and modding to make it work... i also
tried to see if a s2k's rear sway bar would work, slight off but if ever im gonna do the modding
and fabbing i think the s2k's is a much better option than the civic.....
good luck on your hunt! i do suggest get the oem one in front and just get addco for the rear
but if your in a good mood to experiment then do what ive been trying to set, just keep us updated!
Old Aug 8, 2012 | 06:50 PM
Snafu-Si's Avatar
or rather one on the shock tower, not the one under the car that is. I figure I could fit one there as well.
Old Aug 8, 2012 | 06:54 PM
B18C5-EH2's Avatar
Former Moderator
Loved
The bar across the shock towers is called a strut brace, not sway bar or anti-roll bar.
Old Aug 9, 2012 | 12:53 AM
civilrant's Avatar
HTH
Any front strut bar(the one under the hood) will work. just remember that you will run into clearance issue if your still using the stock intake manifold. I highly suggest one. Made a noticeable difference with mine. I modified a civic rear strut bar to work with our V's and its very noticeable as well. But i had to constantly remove it for hauling **** in the back.
Addco rear sway bar is the way to go. you have to trim the bushings a bit to get it on there but otherwise, was a great investment.
http://www.summitracing.com/search/B.../?autoview=SKU
Heres mine
Moog endlinks are the biggest i've found but not by any means the cheapest. Proforged is almost the same size but a lot cheaper.
http://www.summitracing.com/search/D...r/?Ns=Rank|Asc
Old Aug 9, 2012 | 07:03 AM
Snafu-Si's Avatar
my other fear is that my bolts are so rusty that I might snap one trying to remove it. I don't know how stout they are but I know they're pretty rusted up.
Old Aug 9, 2012 | 07:35 AM
www.megameet.org's Avatar
Front upper strut bar with no modes= nuespeed
Rear upper with no mods=cusco
Old Aug 9, 2012 | 08:00 AM
ARMED's Avatar
ultra racing makes it too...check ebay
Old Aug 10, 2012 | 02:09 PM
vwtohonda's Avatar
Originally Posted by civilrant
HTH
Heres mine
Any strut brace bar will work? Like integra or civic? More info please
Old Aug 10, 2012 | 09:29 PM
civilrant's Avatar
on the front yes, mine came off an EG.
The rear was from my old EK HB that got stolen, i just cut about 4" off and then rethreaded the holes.
immajackuup
21
Aug 15, 2008 06:00 PM
DarkBB4
Jun 6, 2006 02:56 PM
triple
May 23, 2006 03:45 AM
H22A4Me
Feb 22, 2006 05:23 PM
