GSR won't hold idle after S2 Manifold Installation
Old Aug 7, 2012 | 10:57 PM
beatontheeznutz's Avatar
Default GSR won't hold idle after S2 Manifold Installation
I installed a Brand New Skunk2 Intake Manifold on my 2000 Integra GSR. Went to go start the engine and it idled around 750 rpm(COLD) and slowly dropped until it died. Idle does not fluctuate. Sometimes it'll starts and idles very low around 250rpm maybe lower and sometimes the engine wont start at all. It was running like a champ before the Skunk2 Manifold installation. I've checked all vacuums and coolant hoses and they're fine. I swapped the stock throttle body along with the TPS and MAP sensor which were untouched. Maybe I did something wrong. I'd appreciate it if someone can help me out. Please.
Old Aug 8, 2012 | 07:54 AM
b20c5eg's Avatar
Default Re: GSR won't hold idle after S2 Manifold Installation
I was reading another post on here, wish i had a link to give you. But I remember reading about the butterflies in the original intake runners and he was having a lot of trouble with vtec. Everybodies answer to him was to get it tuned. Your ecu still thinks the intake still has short and long intake runners. Thought I would share, good luch searching
Old Aug 9, 2012 | 05:56 AM
sirtef9's Avatar
Spray carb cleaner all around where it meets the head, t body gasket and vac hoses. When the idle jumps up you found your vacuum leak.
Old Aug 9, 2012 | 07:51 AM
ThoKMo's Avatar
i dont believe that it is a vacuume leak, after doing a modification like changing your manifold to a high flow manifold you will need a tune. not saying thats the only problem but probably a big majority of it
Old Aug 9, 2012 | 10:04 AM
thangnhocngheo's Avatar
U don't need it tune.. I've install 3 of those already and it's all good.. Check the ur tps and map sensor.. Could possibly wrong connection.. Could possibly clean out ur iavc.. GL
Old Aug 9, 2012 | 10:07 AM
b20c5eg's Avatar
That doesnt make sence because he has all the same sensors and it didnt have the problem before.
Old Aug 9, 2012 | 10:19 AM
solis153's Avatar
I think he ment op might have switched the connectors around.
Old Aug 9, 2012 | 10:42 AM
b20c5eg's Avatar
just for the record, what does op stand for. also, I have ran into that with the tps and map plugs being switched. It idled fine, just would rev correctly. Eather way, I hope its an easy fix. good luck
Old Aug 9, 2012 | 04:31 PM
sirtef9's Avatar
No. The car won't have vacuum leak symptoms from installing this manifold.
Old Aug 9, 2012 | 04:41 PM
haven't checked yet but i think it's a possibilty i've might have put on the throttle body gasket on wrong causing the gasket to block the port that leads to the IACV which controls the idle.
Old Aug 9, 2012 | 07:50 PM
rhymeshark916's Avatar
OP= Original poster, the guy who put up the thread.
If that's the case then you should loudly hear the leak. How's your coolant temp? Put up a picture of your setup. I need help on how to route the coolant lines and PVC hoses.
Old Aug 10, 2012 | 01:56 AM
throttle body gasket is on correctly. i knew i couldn't have put on the gasket wrong. i'll post pictures when i get a chance.
Old Aug 10, 2012 | 07:09 AM
Sukebei Oni's Avatar
If you are still using the stock throttle body, what did you use for the throttle cable? Did you get a type-R cable and bracket? I would test the IACV first and confirm that it is working properly.
Does the engine rev up? can you hold it at 1000 RPM? If it does, do a check on the idle. it might be outof adjustment for some reason.
Old Aug 10, 2012 | 07:32 AM
JDL2Z's Avatar
it wouldnt need a tune to keep idle just from switching the intake manifold. something isnt installed right. take it off and reinstall. during the process you may find where the issue is coming from
Old Aug 10, 2012 | 02:20 PM
i re-used the stock gsr throttle body and gsr throttle cable bracket. worked out fine.
Old Aug 11, 2012 | 04:00 AM
IN VTEC's Avatar
Are the iacv and iat connectors reversed? They're both 2 pin.
Old Aug 11, 2012 | 05:08 PM
going into the manifold swapped i knew the two connectors were similiar but i noticed my tps connector is a blue connector and the map was grey. so thats how i know distinguish the two connectors apart. still nothing. going to pop the IACV off and clean it see if it does anything.
Mr.Fubbs
Aug 28, 2013 04:15 PM
gray89si
Feb 13, 2008 07:17 PM
DVPTeG
Jun 29, 2007 11:26 AM
matt_pound
Dec 3, 2006 07:16 PM
AmauryR
Jan 5, 2003 08:50 PM
