94 db8 code 7 issues wont rev past like 1200rpm
Ok so i have a customers car in my shop i have done many swaps this is the first time i have ever ran into this issue myself or noone i know what the hell it is so ill give this a shot.
The car is a 94 db8 with a 95 gsr customer bought the car as a shell it was stolen. i picked the car up from him along with motor and everything to install. he wanted it back to 100% stock since its his dd. so i have everything installed i went to start it it fired right up i let it idle to get oil pressure and such i reved it and it bounces off what sounds like a rev limiter at like 900rpm-1200rpm it throws a tps code i installed a brand new tps adjusted it right checked volts and all im stumped at this point i have checked all my grounds ohmed all the woires evrything checks out has brand new o2 new dizzy new tps map is good the customer did delete the iacv and the gsr surge tank i can post a video if need too ill will be so happy if someone can help me out with this.
THANKS FOR YOUR TIME
So i decided to pull the throttle body back off and the prongs in the throttle body that alin the tps sensor were bent i have never ever seen that and ive done 100+ hondas i put a new throttle body on it and it runs like new
Thanks for the replys guys but i have been at this car for two weeks i have done a bunch of these and this isa the first time i have ever ran into theis problem
RustyRex
Oct 16, 2003 05:27 AM
