FS: ARP D16Z6, EG CF tailgate, S2K spacers, ITR head/IM/ECU, GSR head/IM/ECU, more!
PM, SMS (410-505-8592), or email (jesse at hondatwincam dot com) is the best way to reach me.
Perrin catch can
- MSRP $130
- $100
- a couple of pics, more here http://hondatwincam.com/fs/perrin/
CF "tailgate" for EG HB
- brand new in box!
- $320 + shipping
- couple of pics, more here: http://hondatwincam.com/fs/cftg/
1-piece S2000 axle / driveshaft spacers
- 1 piece aluminum
- unknown brand
- $50 + shipping OBO
S2000 Hard Top Strikers
- BNIB
- fix your soft top wind noise
- $60 shipped
1997 JDM Integra Type R head
- intake manifold, throttle body, fuel rail, injectors, distributor, plug wires, spark plugs
- ITR exhaust cam, CTR intake cam
- all cam caps, oil spray rails, bolts, COMPLETELY COMPLETE
- $900
- couple of pics, the rest are here: http://www.hondatwincam.com/fs/97jdm_itr_head/
1997 JDM Integra Type R short block
- nothing missing at all
- either #2 or #3 needs new rings, I forget which was low on compression - will disclose to buyer
- $800
- couple of pics, the rest are here: http://www.hondatwincam.com/fs/97jdm_itr_block/
1997 Integra Type R transmission
- 4.4 final w/ LSD
- no grinds, pop-outs, it's in great shape
- slight cosmetic damage to bolt holes for front mount. Threads are fine
- will include extra gear sets (3/4)
- $950 --pending--
- couple of pics, the rest are here: http://hondatwincam.com/fs/97jdm_itr_trans/
1997 JDM GS-R head
- Blox intake manifold, bored OEM throttle body, fuel rail, injectors, distributor, plug wires
- both cams, all cam caps, oil spray rails, bolts, sensors, COMPLETELY COMPLETE
- $600 --pending--
- a couple pictures, the rest are here: http://www.hondatwincam.com/fs/97jdm_gsr_head/
1997 JDM GS-R short block
- still has 00 pistons but it's been apart as the pistons are assembled backwards (arrows point the wrong way)
- compression #s were good but I'd do a hone, re-ring, and re-assemble the pistons correctly (at least)
- $550 --pending--
- a couple pictures, the rest are here: http://www.hondatwincam.com/fs/97jdm_gsr_block/
ARP head studs for D16Z6
- used once
- $80
Hasport mounts, linkage, etc. for hydro B-series swap into EF
- $300 --pending--
Powercore exhaust manifold
- B-series fitment
- 4-1 design, 2.5" collector
- stainless steel
- not some POS cheap Chinese junk
- $150
- some pics, all others here http://hondatwincam.com/fs/pc4-1/
JDM ITR catalytic converter
- flanged to work w/ 2.5" collector
- $100
2.5" test pipe
- non-resonated
- $50
Greddy 52mm boost gauge
- $60
Greddy 52mm oil pressure gauge
- brand new
- $85
OBD1 harness to OBD2 Injector adapters
- brand new, 4 pieces
- plug an OBD2-style injector into your OBD0/1 harness
- $50
Virgin ODB1 P72 GS-R ECU
- $120
- larger versions of this pic here: http://hondatwincam.com/fs/ecus/p72.JPG
Virgin JDM P73 Integra Type R ECU
- $140
- larger versions of this pic here: http://hondatwincam.com/fs/ecus/p73.JPG
Kenji chip for socketed/chipped OBD1 ECUs
- Keni ITR tune w/ 5300 VTEC and 9000 redline
- This is just the chip, no ECU included!
- $30
Autometer mech. oil pressure and oil temp gauges
- used, no instructions
- $50
Batch of EG Civic instrument clusters
- 1x CX or VX (?) cluster with tachometer
- 1x CX or DX (?) cluster. No tach.
- 1x JDM Si-R cluster
- misc. extra cluster parts, a complete tachometer unit, wiring, speedo parts, etc.
- SOLD AS IS I don't have an EG to test these in so I can't guarantee that everything works. The Si-R cluster, for example, looks like the wiring is a little damaged.
- $200
- one pic of almost everything, more here: http://hondatwincam.com/fs/eg_clusters/
Greddy Turbo timer
- brand new
- SOLD to asianboi313
Moroso breather tank / catch can
- brand new
- the same tank used in the Endyn kit
ARP head studs for B18C
- brand new
- SOLD
ARP head studs for B16A
- brand new
- SOLD to markymark885!
Hondata S300
- installed in a P28
- boost controls, no BBG though
- SOLD!
Greddy turbo and manifold for D-series
- just the turbo (TD-04H, no shaft play) and manifold
- manifold is coated black
- SOLD
Greddy turbo kit for 1996-2000 D-series
- SOLD!
Y21 transmission
- transmission from '97 Del Sol VTEC
- perfect shape.
- SOLD to Lesvtec!
S4C transmission
- transmission from '99 Civic Si
- perfect shape.
- SOLD to EKChuck!
1999 B16A2 long block from Civic Si
- ~40k miles on everything, super clean!
- SOLD to Lo-Buck EF!
Perrin catch can
- MSRP $130
- $100
- brand new in box!
- $320 + shipping
- 1 piece aluminum
- unknown brand
- BNIB
- $60 shipped
- $900
- $800
- 4.4 final w/ LSD
- $950 --pending--
1997 JDM GS-R head
- $600 --pending--
- $550 --pending--
- used once
- $80
- $300 --pending--
- B-series fitment
- stainless steel
- $150
- $100
2.5" test pipe
- non-resonated
- $50
- $60
- brand new
- $85
- $50
- $120
- $140
- $30
- $50
- $200
Greddy Turbo timer
- brand new
- brand new
- brand new
- SOLD
- brand new
Hondata S300
- SOLD!
- SOLD
- SOLD!
Y21 transmission
- perfect shape.
- SOLD to Lesvtec!
S4C transmission
- perfect shape.
- SOLD to EKChuck!
*****. I need that shortblock, but also been waiting to hear back about an OEM shortblock...
bump for a great guy to deal with some very good parts!!! hmmm got me thinking over here lol, i"m gonna have to text you about the new project!
Thanks guys, added pics of heads and blocks. I'll get more pics in the thread tonight.
Thanks man! Y21 is now sold as well. Just added Greddy turbo kit and will add more in the coming days.
Bump!
2012-09-03 14:00 EDT - Added Perrin catch can
2012-08-24 11:57 EDT - Moroso catch can and Greddy turbo timer sold!
2012-08-23 11:40 EDT - B16A and B18C ARP studs sold. CF tailgate, S2k parts, Moroso tank, and injector adapters added!
2012-08-22 17:25 EDT - ARP studs added
2012-08-21 18:34 EDT - Greddy manifold/turbo sold!
2012-08-19 21:32 EDT - Greddy kit sold!
2012/08/17 19:05 EDT - Added Greddy gauges, ECUs, and pics of a bunch of stuff.
2012/08/16 18:02 EDT - Added EG clusters and Autometer gauges.
2012/08/11 18:47 EDT - Sold B16A2 long block. Sold S4C transmission.
hondatwincam
Sep 3, 2012 10:00 AM
