eg sounds, setup front speakers help??
need help choosing front door speaker w/components tweeters etc, and amp for mid highs.
i have a kenwood kdc- x696 deck right now. i also have a single type r 12 inch sub ported . mono amp about 500 watts.
my front door speakers have kenwood speakers two front and two rear and front mounted infinity tweeters that came with the car. also needs replacements. all speakers run on stock deck no amp only sub has an amp.
i need help choosing front door speakers w/tweeters. the tweeters crossover old and also i need help in an amp for the front door speakers.
what would be a great setup for fronts. also im new to installing an amp for the front speakers.
what would be a great setup.
Hi,
I prefer JL Audio's C2 speakers. They are super clean and powerful about $250 a pair for components with tweeters and $180 for the rear speakers. This set up always sounds great and won’t break the bank.
Add a bit of dynamat so your door panels don’t rattle $75. You should try and match the amp that you have currently so it looks nice but a JX360/4 will do the trick. $250
okay currently i got an alpine amp from my friend its a alpine mrp-f240 amp. specs will it work?
im planning to wire the front door speakers with the tweeters in the front. will this amp work? for now i am going to use my current front door setups and hopefully change it out later when i get enough money.
the fronts are kenwwood speakers w/ built in tweeter in the middle and the mounted tweeters are infinitys. each door has a crossover .
my question is how do i hook up the amp to my front door speakers. i dont know how to do it whats the meanning of ohms each speaker to ohms wiring it to my amp, how much power watts am i going to run each speaker. whats bridging etc. where do i hook up wires.
im a noob please help
i did a mono amp sub but still i am new to the amp and diffrent channels ohms powers? etc. if i am doing it right
From: Pensacola, FL and every Court House in Louisiana
Hi,
