b16 transmission hard gears. HELP!
i have a 94 eg coupe with a b18b1 swap and a b16 transmission i believe. cant tell if it's really a b16 tranny or a GSR because it has no sticker but it has high gear ratios. my problem i am having now is that when im cruising the gears are fine and shift fine. but as soon as i step on it and speed the gears get hard for them to me to shift after i slow down or try to take off at a light.sometimes they wont go in or I have to kind of Force them in. but if i just cruise for a little while they become smooth again. I've been told that it might be my clutch or pressure plate? and my reverse isnt easy for me to go into either i always have to go to 5th gear then reverse. please help
What size tires and what is cruising RPM at 50mph in 3rd and 5th?
What trans fluid and when was it last changed? What clutch and pressure plate?
i have size 14" tires and my cruising rpm at 50mph in 3rd is about 5200-5300 and in 5th gear its at about 3200-3400. im using oem honda MTF. last time I changed it was about 3 months ago. and i believe it has a oem clutch and pressure plate. i havent removed the transmission at all to see it
Sounds to me like youre low on tranny fluid. When you changed the fluid last how did you do it? Was the car level when you put the fluid in or did you only have the front of the car raised up? Have you noticed any leaking or oil spots in a parking spot that you frequently park at?
