h22 swap?
I support Nick on this one...... unless you can prove beond a doubt that he is who you claim he is then cut him some slack and tell him to search
He has the same name as the troll they mention. But I'm willing to give him a chance. We all know his history. He wont get much slack.
well, thanks for giving me a chance. i tried to explain what happenned in a different thread that i had started. but, honestly, other than the ecu, and transmission, what else needs to be changed over? like i said before, i don't know all that much about this swap. i have heard from a shop that you can usually get the stock accord power steering pump to work with it, with little or no effort. then again, i have also heard that it can't be done no matter what you do. also, if i were to go with the h22, would i be able to use the same CAI that i have now?
[QUOTE]well, thanks for giving me a chance. i tried to explain what happenned in a different thread that i had started. QUOTE]
OINTS FINGER: IT is you IT is you!!!
anyways, yeah and no..you can use the same CAI with some alterring, but the H22 Tb 3" and the accord Cai is like alot smaller. So it wouldnt help ya that much. The PS is going to work. I have just did my swap and i was able to do it. You have to take it to a shop and have the top h22 hose made to fit the lower accord part. ran me 23 bucks. there is alot of stuff like that you might run into. Good luck
I read an earlier post from a guy who said he used the '97+ bracket, Accord P.S. pump, and the Accord P.S. lines. Is this what you did or did you end up getting a shop to splice the Accord and Prelude lines together? Just curious....
[Modified by 4thapack, 1:48 AM 10/20/2002]
I just bolted a 97 powersteering bracket onto the prelude motor
and everything lined up perfectly. I needed like a half inch longer
belt was all.
just used the accord PS line and pump.
belt was all.
just used the accord PS line and pump.Thread
