95 dx coupe-doin brake swap from 97 dc4 abs, what parts do i use
i have a 95 civic dx coupe 5 speed car, and my master cylinder went out. i have been wanting to do a brake conversion so now is the best time to do it. i have been getting info as much as i can about the swap but still have questions. i have purchased new 3/16 stainless steel lines, and the AN fittings needed to do a brakeline tuck and i already have a 40/40 prop valve that is going on the inside of the firewall. the donor car i found is a 97 integra dc4 abs car automatic. i will be purchasing a new master cylinder for a 91 civic ex 4 door. i need to know if the parts off the dc4 are the right parts i need. this is what im thinking that i need. the front spindle/knuckle/hub assembly, and also the rear trailing arm/spindle/hub assembly with e brake cables. also wondering if the rear sway bar will work on my car. i will also buy new rotors,calipers,pads, hardware for a dc4 if these parts are correct. also, if the dc4 abs master cylinder will work, ill use that one, i just dont think it will work because it is the abs one but not sure. please let me know if my thinking is wrong or what i may be missing.
saber1
Nov 11, 2002 11:09 PM
