EJ6 -- Hit curb, popped tire, busted driver axle - push car but won't budge
Old Aug 4, 2012 | 03:58 AM
david420's Avatar
Default EJ6 -- Hit curb, popped tire, busted driver axle - push car but won't budge
So i ran over a large curb mad out of jagged stone and popped my tire. Also the driver axel seemed to come out of its bearing? Basically its toast and i know i need a new one. I tried pushing the car but it wouldnt budge. Does this mean the tranny was affected, I can replace an axel but i really hope the tranny is ok.
Thanks in advance all
Old Aug 4, 2012 | 07:49 AM
Former User's Avatar
Default Re: Busted Driver Axel EJ6 NEED HELP!!
Did you inspect the shift linkage for damage?
The first step is to get the car raised on stands and inspect for damage. Post pictures.
Old Aug 5, 2012 | 07:06 PM
david420's Avatar
Shift linkage is ok.
The car wouldnt move because there wasnt a wheel on it, I thought it would still roll with just 3. And this was the driver side wheel btw so im confused why that happened.
The axel was in bad shape but still drivable, i replaced it anyway.
Thanks for help, i was just worried i fd up my tranny but good thing not.
Old Aug 6, 2012 | 04:03 AM
beecee18's Avatar
There still needs further inspection until car is safe and roadworthy. Our cars rarely can brush off curb shots, they never end up being the same.
Old Aug 9, 2012 | 06:52 PM
david420's Avatar
Really? My car seems to be driving ok.
What are somethings to look for? Things that are commonly or easily damaged.
Old Aug 9, 2012 | 06:57 PM
98civdx's Avatar
Master Detailer
Default Re: EJ6 -- Hit curb, popped tire, busted driver axle - push car but won't budge
Quickest way to tell if something is bent is to simply look at the wheel.
Camber being off, toe, and the caster being screwed is a sure sign of bent parts.
How hard was the hit? I've never seen a civic bounce off a curb without considerable damage. (more then just a tire/axle.
Old Aug 10, 2012 | 01:00 AM
david420's Avatar
I guess i will have to inspect more. Il see how my tread is, however i never got an alignment after lowering it so my alignment is way off.
The hit was slow like 5 mph but it busted my tire cuz of jagged bricks.
Would my camber be neg or pos after this incident?
Old Aug 10, 2012 | 09:40 AM
tunerboy254's Avatar
can we get some pics
Old Aug 10, 2012 | 09:47 AM
98civdx's Avatar
Master Detailer
a 5mph hit broke your axle??
at 5 I really worry too much. Take the car in for an alignment and see how the numbers look.
Old Aug 10, 2012 | 12:16 PM
david420's Avatar
No i thought i broke an axle but really it was just damaged slightly, the boot is ripped off almost completely.
I will try to get some pics up, i might just have my friend check my alignment though if you think that would be a good indicator whether there was significant damage or not.
Old Aug 10, 2012 | 12:17 PM
98civdx's Avatar
Master Detailer
The alignment will tell you. Sometimes you can't spot a bent part just from looking at it.
I know if my firends case, he said everything looked "ok" but when he went in for an alignment it was another story. He hit the curb a lot harder then you did though.
Havok114
Jan 30, 2013 12:47 PM
B-EVERYTHING
Jan 30, 2009 10:41 AM
Jonknee
Nov 18, 2006 02:17 PM
PINKS
May 28, 2006 11:13 AM
silverpenny
Jul 14, 2003 10:09 AM
