Transmission & Drivetrain Gearboxes, Differentials, Clutches
Rebuilding LS transmission
Old Aug 3, 2012 | 06:50 PM
metalhelixx's Avatar
Default Rebuilding LS transmission
I have a A1 transmission for my b16a I personally ****inggg hate it!
Anyhow, I have a S1 cable transmission short geared, sitting in the shop.
There is a little gear at the end of the countershaft, It has a little chip, so i figured it's no good.
Is there a way when I rebuild my LS transmission, I can take out the 2nd, 3rd and 4th gear of the s1 transmission and just swap them on? the final drive is the same as the a1 I believe they're both 4.400 final drive.
What's that little gear at the end of the counter shaft, is it better to just replace that little piece?
Old Aug 4, 2012 | 04:47 PM
Aquafina's Avatar
Default Re: Rebuilding LS transmission
If it is the gear under the snap ring bearing on the countershaft it is 5th gear.
xotic_crx
Dec 24, 2015 11:17 AM
blue ej8
Apr 26, 2013 07:47 AM
feriotypeR
May 11, 2010 10:27 AM
raene
Jun 2, 2003 08:40 AM
Nighthawk GS-R
Apr 22, 2002 03:57 PM
