Suspension & Brakes Theory, alignment, spring rates....
Bad Tire wear
Old Aug 3, 2012 | 02:09 PM
Vizio2012's Avatar
Default Bad Tire wear
So i just got my car like 6 months ago and i have very bad camber wear.. And i have searched the forums and what not found a topic you dont need camber kit, and then there is people saying you do??? Looking to fix this fast it has ate all my tires up..
I drive 99 civic si that has been lowered and no i don't know how far i bought the car that way..
Old Aug 3, 2012 | 02:12 PM
spAdam's Avatar
Loved
Community Favorite
Default Re: Bad Tire wear
Toe wear. Whoever lowered it did not get it aligned afterwards, you've been dragging the tires sideways down the road. Probably handled like poo also.
Old Aug 3, 2012 | 02:16 PM
Vizio2012's Avatar
So it just needs a aligned? All my tires are that way the front is worse then the back, but the back is also wearing on inside too.
Old Aug 3, 2012 | 02:21 PM
Vizio2012's Avatar
The wheels are 18's
Old Aug 3, 2012 | 02:26 PM
Vizio2012's Avatar
And i don't think that the middle of tire has been wearing that much, i think first pic i posted made it look that way..
Here is another pic of the tire.
Old Aug 3, 2012 | 05:22 PM
spAdam's Avatar
Loved
Community Favorite
What kind of car? They don't really do front end alignments anymore, it's always four wheel. And yes, any adjustment to the ride height always affects the toe, and ultra low profile tires are especially sensitive to it. I can see the scalloping in your first picture.
Old Aug 3, 2012 | 07:51 PM
Vizio2012's Avatar
It is a 99 civic SI.
Old Aug 3, 2012 | 10:33 PM
spAdam's Avatar
Loved
Community Favorite
Yes. You most definitely need an alignment. No, you do not need adjustable camber, although it is nice to have.
Old Aug 4, 2012 | 12:42 AM
Vizio2012's Avatar
Thanks, and why is adjustable camber nice to have? Sry i am new to this stuff.
And i will call see about getting it aligned this week, i need to before i blow a tire. Hopefully they dont charge a arm and a leg.
Old Aug 5, 2012 | 06:03 PM
Libertariat's Avatar
Ek Forever y0!
Adjustable camber is just nice to have so you can add camber or even the camber from side to side. Some camber is always a plus, once you get over 2* camber you can really tell a difference in handling.
And that's definitely not camber wear. Looks a lot like your tires were over inflated more than anything else.
Old Aug 6, 2012 | 06:37 AM
kyden's Avatar
it just looks like your car was rubbing on the inside. that part of the tire doesn't even touch the ground.
Old Aug 6, 2012 | 07:43 AM
spAdam's Avatar
Loved
Community Favorite
If you zoom in on the first pic that the op put up you can see the "scalloping" that you get from toe. I have seen plenty of tires just like that over the years from people who thought they could just drop the car and not align... Including myself in my younger days.
Old Aug 6, 2012 | 09:43 AM
cdaiscool's Avatar
Similar thing was happening to me.
Got 2 new tires, left the rears alone but got a 4-wheel alignment. The rears stayed okay for 6 months, then blew out on me. Got 2 more new ones at the time, and had zero issues after that.
Alignment is everything. That was LITERALLY all I changed.
Old Aug 6, 2012 | 03:06 PM
Vizio2012's Avatar
Well I know for sure my tires are not rubbing something on inside that much I would hear it. And I have another question if I get a alignment will it push the top of my tire into the fender cause my car is tucking the tires alittle. ?
Old Aug 6, 2012 | 03:18 PM
Vizio2012's Avatar
Yeah looks very similar, what worries me now if it will touch the fender on the outside after I align it. The bottom will be pushed I'n which would make the top push out right? Will the car be raised any when they level out the tires?
Old Aug 6, 2012 | 05:07 PM
grumblemarc's Avatar
The Grumpiest
You don't have a choice so trying to analyze it will make no difference. Get the alignment. If you think the sidewall will contact the fender then raise the ride height then get the alignment.
Old Aug 6, 2012 | 08:36 PM
Vizio2012's Avatar
Yeah your right sometimes i wish i had factory SI springs to lift it back to factory.
Fel_15
Nov 23, 2009 09:12 AM
Understeer
Suspension & Brakes
Jun 29, 2005 05:09 AM
vsm dc4
Suspension & Brakes
13
Feb 7, 2005 04:37 AM
Kyles ej1
Jan 8, 2005 04:07 PM
theguy003
Jan 25, 2002 05:08 PM
