resistor box ?
Old Aug 3, 2012 | 06:40 AM
EJ7-4dr's Avatar
Default resistor box ?
okay I have a p72 ecu,96 to 98 ex ewh,d series injectors 94 b18b1 ls motor I made it all it obd 2
? I have do I need a resistor box for this set up its going into 97 civc lx
Old Aug 3, 2012 | 07:22 AM
MonkeyMagic's Avatar
Default Re: resistor box ?
lol wat?
"d series injectors" are they from a 88-91 ex/si? then yes
are they from a 92+ civic? then no, no resistor box.
normally i'd knock the setup, but seems you're going b series as best you can.
keep it up
Old Aug 4, 2012 | 06:40 AM
sir 97's Avatar
you need to check the fuel injector resistance
if it around 12 its hi no need for resistor box
if it around 3 you need to add resistor box
Old Aug 6, 2012 | 08:23 PM
EJ7-4dr's Avatar
Hey guys,
Thanks for getting back to me the reason I was thinking of using d series injectors because from what I read d and b series are both at 240cc not sure if this is correct but also the d series injectors I have are obd 2 I do have my ls injectors but there obd 1 I didn't want to use these cuz of the whole cut and splice thing trying to keep my wiring original as possible is there a harness kit for injectors obd 1 to obd 2? What do u guys think I should do
Old Aug 7, 2012 | 07:16 AM
kyden's Avatar
it depends. there are different injectors for a d series from 96-00. the d16y7 are 190cc and the d16y8 are 240cc.
Ek4 SiR
Mar 3, 2011 07:15 AM
simplsi
Jun 21, 2008 12:34 PM
wish_i_was_h22a
May 22, 2006 08:51 PM
lowexr
Nov 11, 2002 08:20 AM
