what is the fastest,best,reasonable motors to swap into a 90 ef hatch
Old Aug 2, 2012 | 05:30 PM
ef hatchDUDE's Avatar
Default what is the fastest,best,reasonable motors to swap into a 90 ef hatch
just want some opinion on this
Old Aug 2, 2012 | 05:35 PM
KINGVEM^^ED6's Avatar
Default Re: what is the fastest,best,reasonable motors to swap into a 90 ef hatch
Big block chevy motor
Old Aug 2, 2012 | 05:43 PM
Black R's Avatar
25 Year Member
It really boils down to budget and intended use / whp goal.
I'd say some version of the k24 na.
Boosted, b or d.
Old Aug 2, 2012 | 05:56 PM
i just want reliable daily driver that will smoke foxbodys,irocs,firebirds
Old Aug 2, 2012 | 06:34 PM
neophish's Avatar
turbo b18a = best bang for the buck imo
i'd be building one if i had the moo-lah
Old Aug 2, 2012 | 06:39 PM
doood's Avatar
been there done that
you still havent given any indication of a budget. people can recommend everything under the sun but if you cant afford it what's the point?
Old Aug 2, 2012 | 06:45 PM
1000$ is my ideal budget
Old Aug 2, 2012 | 06:47 PM
doood's Avatar
really?
keep saving, or dreaming.
Old Aug 2, 2012 | 06:48 PM
Ls swap
Old Aug 2, 2012 | 06:57 PM
ef_newb's Avatar
can't esplain that :confused:
1. fast
2. reliable
3. cheap
you can only choose 2 bruh
Old Aug 2, 2012 | 07:06 PM
whats a price that will work??
Old Aug 2, 2012 | 07:08 PM
Id say 3500-4000
Unless you do all the work your self
Old Aug 2, 2012 | 07:11 PM
if i had a price of 4k what would the best swap be??
Old Aug 2, 2012 | 07:12 PM
bgdriver's Avatar
f23
Old Aug 2, 2012 | 10:45 PM
xef_twinx's Avatar
A fast reliable good gas mileaged motor would be a Jdm obd0 b16a out of da xsi but since those are hard to come by I recommend either a Jdm dohc zc(bolts right in And is around 800 or so) a Jdm d15b Vtec or a d16z6 or y8 all those are reliable aren't the fastest but theyre peppy and parts are cheap and easy swap since your d series already. Plus you turbo a well built y8 and you can see some good numbers an reliability
Old Aug 3, 2012 | 01:15 AM
TeamRedline89Hatch's Avatar
b20, b16 trans ls 5th. Great torque and power and cruising 70 @ 3200 rpm makes great mpg. But can you do that with $1000? Maybe if you really searched a pieced the swap together. Good luck with whatever you choose.
Old Aug 3, 2012 | 01:48 AM
Nooch's Avatar
You also haven't explained your background in turning a wrench. Unless some shop is doing this for you your most likely option (as I'm guessing at least) is going to be a dohc zc or sohc zc. It'll be the most easiest swap possible and be reliable and 'peppy'. Easy to come by and parts are all over. If you have all the tools and required **** before hand you can do the complete swap for under a thousand.
Old Aug 3, 2012 | 04:38 AM
EFinAwesome's Avatar
It's sad threads like this get the most attention. Swap a z6 into it then save up another $1200 turbo it and there's 200whp
Old Aug 3, 2012 | 10:43 AM
91EFH22's Avatar
Old Aug 3, 2012 | 11:20 AM
sxysweed's Avatar
Vitara/Holeslut D16.
Old Aug 3, 2012 | 11:23 AM
Originally Posted by 91EFH22
how much did that swap cost?looks real nice...
91 EF DX's Avatar
More than a grand
Old Aug 3, 2012 | 01:57 PM
91EFH22's Avatar
Originally Posted by 91 EF DX
More than a grand
Yup!
Mounts (with traction bar) 850
motor trans and ecu 1000
axles 280
exhaust 3" (myself) 150
jumper free with car
wiring (myself)
install (myself)
Doing it myself probably saved me $2000 alone! It wasnt that bad
Old Aug 3, 2012 | 02:03 PM
Black R's Avatar
25 Year Member
H2B puts it out of the park amirite?
Old Aug 3, 2012 | 02:14 PM
JDpower's Avatar
[IMG]<a href="http://s1199.photobucket.com/albums/aa477/89jdmcrxDOHCzc/?action=view&amp;current=DSC08220.jpg" target="_blank"><img src="http://i1199.photobucket.com/albums/aa477/89jdmcrxDOHCzc/DSC08220.jpg" border="0" alt="Photobucket"></a>[/IMG]
