HUGE SALE QUALITY PARTS
need these parts gone they are just taking up space
Ap1 cluster with pig tails was told around 88k by a good buddy of mine light scratch maybe a 1/4 inch text for pics $260
Hybird 96-00 full size griffin radiator never used only mocked up a few times, some bent fins from being moved around. No radiator cap I have both sensors as well that can be included for an additional $50
$310
alex racing brackets new have a few light scratches from moving around storage to storage.
$130
prb 02-04 type s ecu one of the mount tabs is broken but it is fully functional
$180 shipped
K20a cams with only 30k max pulled from my personal engine (stored properly)
$250 shipped
toda spec b brand new exh cam
$300 shipped
Carbing roll bar all new allen head hardware.
Offers (dont low ball)
complete 4x100 gsr set up powder coated gloss black (looks amazing) has all new oem wheel bearings all the way around along with new oem hubs, new arp oem length studs new Mfactory lower ball joints subframe is powder coated along with control arms and all hardware is nickel plated. Hard race bushings all the way around as well. buddy club new upper control arms and pic rear controls can be included as well. HAVE NEW NUT TO REPLACE TO RUSTED ON PICTURED AND ALL NEW AXLE NUTS
Will consider serious offers this set up is very nice and would look great on a ground up resto. Just in parts I have over $1,000 in the set*
rays gram light center cap black ring with silver enter*
$40*
96-98 sir front lip new in the package with new oem hardware as well
$220
brand new 96-98 hybrid harness spliced into brand new oem 98 dx dash harness ac/heater core plugs deleted very clean job done by Chase.
$280
complete 94-95 eg ac set up hybrid racing used for maybe 3 months includes all lines condensor compressor drier fan etc.
$340
cut 96-98 hybrid harness came off running car not sure what wire was cut...
$70
2 water pumps $40
2x ac comp $50
2x ps pump $30
Obx ek1 mounts used for mocking only*
$120
Bare k20a2 block and girdle good shape cylinder walls are clean
$125
COMPLETE (minus tb have exhaust and intake if wanted for noncharge but no tb) k20a2 head clean valve clearances checked all to spec includes valve cover all sensors. 70k comes with coil packs everything.
$450 firm will drop the price if parts are not needed
K20a2 short block with spun rod bearing no oil pan its complete besides that and cracked knock sensor includes pulley and side cover. Vin intact around 80k
$200
K24a1 head super clean and complete minus coils. Cam lobes have some mild surface rust but they can be cleaned and usually are not even used. Realll clean
$250
It's custom I have the codes between mica matador red pearl and tengo red pearl on new si
K24a1 bare block with crank and girdle very low miles on this I would say like 50k max vin is still intact I have an oil pan and pump I can include as well. Very very slight surface rust on the cylinder walls but it was easily removable with oil so I will clean it prior to selling.
$150
K20a2 Short block with no accessories will include timing cover and crank pulley. NO starter alt halfshaft or knock sensor. Very clean was a virgin motor n
$375
K alt $75
K starter $75
Gsr cloth arm rest clean
$20 a piece
eg side skirts clean
$40
eg manual door panels
$30
ek gauge surround with dual gauge pod
$20
mugen b series t stat
$40
rear dc t bracket
$20
gsr door panels cloth with switches
$30
k tuned pasg side hoses never used
$50
oil line for turbo
$20
dc cluster 110k
$40
gsr cams
$30
half size oem radiator
$20
d series throttle body
$15
will add more parts soon
16304085933
PICS WILL BE POSTED
text for pics
$310
$130
$180 shipped
$250 shipped
$300 shipped
$40*
$220
$280
$340
$70
2 water pumps $40
2x ac comp $50
2x ps pump $30
$120
$125
$200
$250
$150
$375
K alt $75
K starter $75
$20 a piece
$40
$30
$20
$40
rear dc t bracket
$20
$30
$50
oil line for turbo
$20
dc cluster 110k
$40
gsr cams
$30
$20
$15
16304085933
PICS WILL BE POSTED
text for pics
dc2twincam
Dec 19, 2012 08:54 AM
dc2twincam
nutt45
Northeast (Sales)
May 27, 2010 04:20 AM
