type-r sway + benen rear lower tie bar?
Old Oct 15, 2002 | 05:23 PM
SamuraiJack's Avatar
Default type-r sway + benen rear lower tie bar?
would a benen rear lower tie bar work with the type-r sway bar?
i know the some of the rear lower bars dont work with the 22mm sway bar
TIA
Old Oct 15, 2002 | 07:16 PM
Shark Tank's Avatar
Default Re: type-r sway + benen rear lower tie bar? (SamuraiJack)
yes, i used to run that setup. no advantage really from the lower tie bar IMHO. i tried it both ways and i found no real difference
Old Oct 15, 2002 | 08:03 PM
AcuraRacer112's Avatar
Default Re: type-r sway + benen rear lower tie bar? (CART fan)
Cart Fan said it Lower Tie Bar = no real advantage
however the type R rear sway bar...OMG I cant say enough good things about it since i put mine on...good god...I love sharp corners now!!!!!
Old Oct 15, 2002 | 08:04 PM
Shark Tank's Avatar
Default Re: type-r sway + benen rear lower tie bar? (AcuraRacer112)
yes the itr sway bar is a must, so much better than gsr bar
Old Oct 15, 2002 | 08:36 PM
point taken. but was there any type of modification to make it fit?
Old Oct 15, 2002 | 09:11 PM
Aaron M's Avatar
what about a rear upper strut bar, any noticeable advantages with having one of those.
Old Oct 15, 2002 | 09:13 PM
Shark Tank's Avatar
Default Re: type-r sway + benen rear lower tie bar? (SilverB18C1)
you need to get a kit from Beaks or BSQ to mount the itr sway bar correctly. the kits run from 35-60.00 for all the hardware and everything. i havent run a rear strut tower bar, but in the end i think it will stiff up the car a little bit. that might be a better route than the rear lower tie bar. but the rear STB is my next thing to add to the car
Old Oct 15, 2002 | 09:45 PM
BlueTeg's Avatar
BSQ is great kit. killer price
But if you're dead set on getting a tiebar also. You might want to look at the rear subframe brace that Comptech sells w/ their swaybar kit.
Kill two birds w/ one stone. Get your tiebar and the reinforcement kit.
Be sure you ask for the subframe brace, their tiebar is a completely different part and will do nothing to keep the swaybar from tearing out.
Old Oct 15, 2002 | 11:07 PM
Default Re: type-r sway + benen rear lower tie bar? (BlueTeg)
im going with the beaks kit
[Modified by SamuraiJack, 12:08 AM 10/16/2002]
Old Oct 15, 2002 | 11:36 PM
Calavera's Avatar
Me and someone else (named shobo or something like that) on this board had fitment issues with the benen tie bar and 22mm ITR sway bar. There wasn't enough room/clearance. The lower bushing bolt hindered the tie bar from bolting on all the way.
This was fixed using washers with the benen bar. You can find some at local autoparts shops or simply order from Beaks. He specifically makes a seperate beaks that consists of two spaces and longer bolts that solves the Benen/ITR sway problem. You can find it on beaks website. Email him if you're not sure what to get. He'll know.
Old Oct 15, 2002 | 11:39 PM
Default Re: type-r sway + benen rear lower tie bar? (Calavera)
yea i saw that section, extra $10bucks
DC2 Mang
Suspension & Brakes
12
May 12, 2020 09:12 AM
Cody08
May 1, 2018 09:28 AM
toguemaster
Apr 25, 2006 04:33 PM
^Sammy]!.
Feb 7, 2004 08:15 AM
Thrillhouse
May 14, 2003 05:50 PM
