P0118 code, but temp gauge works fine
Old Aug 2, 2012 | 03:24 AM
jones89m's Avatar
Icon2 P0118 code, but temp gauge works fine
I have a 1996 Civic that is repeatedly throwing code P0118 Engine Coolant Temperature (ECT) sensor circuit high input shortly after starting the car. But the temperature gauge works fine.
This started after I had the transmission (manual) changed so I suspect something did not get reconnected, but the mechanic cannot find anything.
This was also the first time using this mechanic (chain) since the one I went too since I was a teenager went out of business.
Any thoughts on exactly where to look when you get a P0118 but the gauge is still working fine?
Thanks
Old Aug 2, 2012 | 05:24 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: P0118 code, but guage works fine
The gauge has nothing to do with it. This is the ECT and testing:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/ect-o2-running-rich%3Dbad-mpg-2618622/
Old Aug 2, 2012 | 06:48 AM
Former User's Avatar
As Hero says, the temp gauge in the cluster uses a different temp sensor -- the 1-wire sending unit under the distributor.
The 2-wire temp sensor (ECT sensor) under the distributor is the one you need to focus on.
Old Aug 5, 2012 | 09:18 AM
jones89m's Avatar
Thank you both for your replies, today was the first day I had to look at it.
Following your instructions found the ECT under the distributor.
Anyways tested the ECT with OHM meter, 1699 cold, and in range of 200-400 when warmed up. So it is good.
Tested the voltage as indicated, red/wht >> grnd = 5v, red/wht >> grn/wht = 5v. From there the diagnostic page in the link says to substitute with a known good ECU, which I do not have.
Would there be anything else I can try other than going to a dealer?
P.S. I already changed the coolant and bled the system as a post somewhere had said dirty/low coolant could contribute to a PO118 code.
Old Aug 5, 2012 | 09:23 AM
If you reset the ECU, does the code return? If so, then the ECU may be bad.
Old Aug 25, 2012 | 02:42 AM
jones89m's Avatar
Default Re: P0118 code, but temp gauge works fine
this is the kids car and I hadn't gotten to try resetting the ECM yet, but the check engine light went back off on it's own now. Nothing changed that I am aware of other than the weather has gotten cooler and more seasonable.
So the light is off and I am just going to hope it stays off. If it comes back on I will try resetting the ECM.
Thanks again for you help.
gabrielsousa
Sep 23, 2014 09:26 AM
98cwitr
May 18, 2004 01:13 PM
erniecars
Jun 14, 2002 11:48 PM
