Will a 88-91 Crx si Dash Fit into a 1991 civic si hatch?
Old Oct 15, 2002 | 05:19 PM
STHPERFORMANCE's Avatar
Default Will a 88-91 Crx si Dash Fit into a 1991 civic si hatch?
well as the topic says, i am wanting to know if the 88-91 crx si dash fits into my 1991 civic si hatch car??????? please post as much info as you know.. thanks
Old Oct 15, 2002 | 05:30 PM
wannab20hatch's Avatar
Default Re: Will a 88-91 Crx si Dash Fit into a 1991 civic si hatch? (OutKast)
Yup it sure will. only thing you have to change out other than the dash is center console and air control supports.
Old Oct 15, 2002 | 05:31 PM
excitid's Avatar
yes it fits. I'll try and post you a pic later.
Old Oct 15, 2002 | 05:32 PM
Proper's Avatar
http://www.4gcivic.com has a thing on this in their How-to's section. I think it tells ya everything you need and what to do with it
Old Oct 15, 2002 | 07:11 PM
Default Re: Will a 88-91 Crx si Dash Fit into a 1991 civic si hatch? (SOHC'd up)
To the top, pics please... BTW that last link didnt work.....
Old Oct 15, 2002 | 10:26 PM
JOEY F.'s Avatar
damn i wish i knew how to post pix of my 88 dash in mah 91 DX...well, the thing is the wiring in the cluster from 88-89 to 90-91....if you swap dashes from 90-91 crx's to 90-91 civic's its a piece of pie....(vice versa fer 88-89 years) after that all you do is swap out the center console from and your done!....oh yah.....cant use the CRX a/c control....too much werk!...just use your cable A/c controller..
Old Oct 15, 2002 | 10:40 PM
Ham'ed Hatch
Guest
Posts: n/a
Default Re: Will a 88-91 Crx si Dash Fit into a 1991 civic si hatch? (josEF)
you also need to go to honda and buy the appropriate pedistal mounts for the cluster. even if you have a 90 car/cluster and your putting in a 90 crx dash, your cluster will sit about 1/2in too high leaving an ugly gap. so if you can get it with the dash, good for you, if not go to honda, it was only 3 bucks for both mounts.
Old Oct 15, 2002 | 11:55 PM
RuthlessEF-9's Avatar
Default Re: Will a 88-91 Crx si Dash Fit into a 1991 civic si hatch? (Ham'ed Hatch)
it will work just ***** rig it all i did it in my 4dr and its pretty pimp thats the first thing people notice when they look in my car
Old Oct 16, 2002 | 03:46 AM
SuperCivic's Avatar
Default Re: Will a 88-91 Crx si Dash Fit into a 1991 civic si hatch? (D16z6turbs)
http://forums.civicland.com/viewtopi...354&forum=22&4
i wrote this how-to ages ago when i first did the dash swap. warning: it's really long.
Old Mar 19, 2010 | 12:36 PM
josem20058's Avatar
TRIAL USER
i have a question...and will a 1990 civic hatch si wiring work for a 1991 crx si??? i need to know please help...
Bertamus
Oct 18, 2010 05:16 PM
Gen4Si
Jan 30, 2005 03:38 PM
kevinm1981
Jul 8, 2003 12:34 PM
EF-9SiR
11
Sep 3, 2002 10:46 AM
