Hawk race pads
If you try this little trick you will find all kinds of information on brake pads.
Go to google... search brake pads, and use honda-tech in the search string.
There is such a plethora of information on all kinds of manufacturers and types its mind boggling.
A little reading will get you the information you desire.
If you dont read and post up something like Tires.. do i really need them?
Stinkycheezmonky will send his good friend Frank over to your house.
Who is Frank? He is a midget and he will shave your eyebrows off.
So please read
I use the dtc60 on the front of both of the 92 civics I have.
One is a 160hp Honda Challenge H2 car with 160hp with Wilwood calipers and 11" corrado rotors, 2250 lbs with driver. They work great, zero fade, even after our annual 3hr enduro this past weekend.
The other is 350hp time trial car, with NSX calipers with 11" mini Cooper rotors, that setup will experience a little bit of fade on heavy braking tracks after about 7 hard laps.
Both cars use oem GSR calipers and rotors in the rear with axis ultimates which would be the equivalent of an HPS pad from hawk.
broketuner-Sol_Si
Dec 6, 2006 01:19 PM
ghettoracer
30
Jul 19, 2003 01:15 PM
