Low Oil pressure & Random smoking??
Old Aug 1, 2012 | 01:59 PM
EJ8Squad919's Avatar
Default Low Oil pressure & Random smoking??
Just finished my build its a 81.5mm Ls vtec with darton dry sleeves with CP 9.0:1 pistons, eagle rods, acl x racing bearings, stock ls crank, brand new oil pump, water pump, etc. I used castrol gtx 10w30. When we were tuning it was really hot i mean it was like 100 degrees outside. I only did 2 pulls n saw i had really low oil pressure. At idle its at like 5psi, 3k its at 25psi. This only happens when the engine is hot. I checked the oil and its fine not low or anything. My tuner said it could be the acl x rod bearings i used causing the low oil pressure and cuz of the eagle rods, and that im boosted but i dunno. After running the car a little hard i pop the hood n see smoke coming from the valve cover bolt where the spark plug cover goes. Im using a breather box and only on 10psi is that normal? Im also seeing smoke come out from my feed line or by my feed line what does this mean?
Old Aug 1, 2012 | 02:06 PM
Dc4LsTeG's Avatar
EK9
Default Re: Low Oil pressure & Random smoking??
What were your bearing clearances?
Old Aug 1, 2012 | 02:55 PM
I have no idea. The machine shop did everything for me. This sis my first big build and still learning. All i know is that i used acl main bearings and acl x bearings for the rods.
Old Aug 1, 2012 | 04:40 PM
Im running a greddy oil pressure gauge on the back of the block where the oil switch was. The car has perfect oil pressure when its warming up its only bad when it gets really hot i live in florida and gets really hot.
Old Aug 1, 2012 | 07:04 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
The bearing brand has NOTHING to do with it... the clearances do. If an even remotely reputable shop did the work they would have given you a build sheet with the specs. The type of rods have absolutely nothing to do with this either. Also, I doubt it was broken in remotely correct either. The temperature plays a role but has little to do with it like you are experiencing. We need more information.
Old Aug 2, 2012 | 02:58 AM
rich7777's Avatar
Give it back to who built it... it's their problem, not YOURS. It's definitely down to assembly.
Old Aug 2, 2012 | 04:40 AM
fcluddington's Avatar
That's some pretty low oil psi, sounds like you are stuck with the engine the way it is and you are just trying to get oil psi up when engine is hot. If 10w30 is 5 psi at idle when hot, drain it change filter and go with 2-3 grades thicker oil. Hell If I had that low I would use Rotella 15w-40. just be sure to take it easy when engine is warming up.
BTW what are your current oil psi at initial start up?
Old Aug 2, 2012 | 04:48 AM
Muckman's Avatar
Moderator in Chief
It should be at least 10psi at idle fully warmed up. Try a 20w50. Sounds like your builder used large bearing clearances. Or if it wasnt always this low - it could be indication of a spun bearing.
Old Aug 2, 2012 | 07:06 AM
blackeg's Avatar
yeah at least 10 psi hopefully into the 20's....remember the general rule, 10 psi per 1000 rpm.
how hot are your oil temps?
either way, this engine needs to go back to the builder
Old Aug 2, 2012 | 07:42 AM
DO IT ON ALL FOURS
That general rule is for "old school" domestics. Given, to a point it holds some truth for Honda's but you will find they tyoically only need around 80 psi up towards even 11,000 rpms. It has more to do with oil supply and make-up than RPM. Oil shear is determined by the oil, remember that.
Old Aug 2, 2012 | 02:01 PM
Yea im going to try thicker oil and see what happens. When cold its at like 85psi. When temps get higher the oil pressure drops.
Hondoctors
Aug 5, 2020 04:59 PM
Dontoh
May 14, 2013 04:55 PM
turbolsvtecej1
Sep 12, 2011 05:59 PM
turbo boost
Apr 21, 2007 03:42 PM
doublejz
Feb 12, 2006 10:34 AM
