ITR Cluster to 97 LS; Fuel Gauge Not Working;
greeting everyone, thanks for the help in advance.
I recently swapped my 97 LS cluster with a friend that had a ITR one in his 94 teg. i installed my new ITR Cluster with plugin it in, but there are some things that doesn't work right immediately.
Things NOT working,
Need Reassignment
ABS (this is where the SRS light was in the other cluster, before the swap was on, so i think i need to use the seatbelt marker instead)
Seatbelt (is located where the abs light was so i thing i only need to swap it
with the ABS, ABS was on, pump is not working)
Need Explanation on;
the Check Engine Light Was Off but now its on a random basis, i need to know if its well mapped.
Cluster Pic
https://i.imgur.com/7el9p.jpg
Things NOT working,
- Fuel Gauge;
- Battery Light;
Need Reassignment
Cluster Pic
green film means getting another whole cluster;
you take the film off your ls harness.
or you just use a 96-97 spec itr cluster.
in order for this cluster not to be working and the fact it did work in an obd1 gsr means that it has obd1 film on it.
i thought this problem could be resolved with repin some wires in the connectors of the cluster. now i need to hunt another cluster;
i thought you got it from a friend? see if he still has the jdm film.
looking at the diagram in the back of the cluster, it looks like on 98+ the fuel signal wire is at pin b1, and on 94-97 it is on b3. try moving the pin over?
i suppose you could switch the pins for abs + the seat belt light if you wanted to also.
came out of 94 teg working
not working in 97 teg?
just saying..
i haven't troubleshot clusters or kept up on all the changes but that alone would tell me something is different
i know the 98+ are
just saying..
i know the 98+ are
same issue i had. i just had a edm cluster from a 98r worked perfectly in my 00gsr. put it in my 95gsr and had the same issues your having. i just swapped the green film from my orignal 95gsr cluster to the edm cluster. everything works perfect! i have another cluster to bad ur not local!
thanks;
the change has to be simple, its inverting the ABS and SeatBelt and getting the fuel gauge to work. i will try this tomorrow;
easiest way is just swap the gauges from one to the other (white housing) and make sure the films on the right ride that have the abs, door, seat belt etc.
