95 civic dx engine swap to d16z6 - need help with wire harnesses
Old Jul 31, 2012 | 08:00 PM
devon23hchs's Avatar
Icon2 95 civic dx engine swap to d16z6 - need help with wire harnesses
i just put a z6 in my sedan but the z6 wiring harness won't wire up. i have the orginal harness that came with the z6 and the p28 ecu but i need help on how to wire it all up.
Old Aug 1, 2012 | 01:32 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: 95 civic dx engine swap to d16z6 - need help with wire harnesses
Just plug it in at the shocktower and run the VTEC wiring from there to the ecu .
Old Aug 1, 2012 | 05:45 PM
Icon2 Re: 95 civic dx engine swap to d16z6 - need help with wire harnesses
ok thanks but the z6 wiring harness won't connect to the original d15b7 shock tower plug
Old Aug 1, 2012 | 05:49 PM
Technical Hero
Can you post a picture because it should. From my knowledge all 92-95 Civic and 92-95 Integra will plug into each others shock harness.
Old Aug 2, 2012 | 09:57 AM
O ok...that's probably my problem then because
The harness for the z6 is off of a 96 civic.
lilo_goki
16
Aug 4, 2007 03:20 AM
crazy sohc vtec guy
Mar 25, 2007 12:52 AM
coreypoppej6
Apr 16, 2005 12:42 PM
labatia
10
Aug 17, 2004 03:56 PM
I Gotta Question
Jan 2, 2003 03:51 PM
