crx with b18a1 swap slung rod bearing help
i have a obd0 b18a1 which recently slung a rod bearing, the crank is scared what is the best way to go with this? 1.find new crank or 2.get a machinist to fix it and what would i have to do after machinist fixes this?
Take the crank to a machinist, they can tell you if it is still within spec or if it will need to be turned down. If it needs turned down, you will have to buy oversized rod bearings from the parts store and then just put it back together.
orod917
Engine Machining & Assembly
May 13, 2019 10:38 AM
SkRiBLaH
Jul 28, 2004 10:24 AM
canuck-mx6
Jun 3, 2002 04:38 PM
