mpfi harness conversion Question
i recently got a hold on the mpfi setup (complete) and the whole ex harness. would i be at a better start by using the whole harness or rigging the ecu connectors?
If your car is a 90-91 then I would swap the entire harness if your afraid to deal with wiring. You just gotta pay attention to what plug goes where. If its a 88-89 then just do the conversion
Another question that just popped up. i got this setup from an EX model i do not know if it was the 1.5l or 1.6l (is it all the same?) the replacement injectors i bought are for the 1.6 even tho my motor is still a 1.5 did i 'ef' up??? i just figured that the inj are designed to work for the setup that i bought. thanks ahead of time
delsizzle1
Dec 8, 2011 12:25 AM
nostreble
Oct 10, 2008 12:32 AM
