Whats the best wayto check a/c compressor relay?
Old Jul 30, 2012 | 06:05 PM
bionichicken's Avatar
Default Whats the best wayto check a/c compressor relay?
I need some help to see if it has anything to do with blowing my #56 fuse (condensor fan) Thanks for any help
Old Jul 31, 2012 | 12:02 AM
SIR 1.6's Avatar
Default Re: Whats the best wayto check a/c compressor relay?
I would also like to know. My 91 SI compressor wont engage. Compressor isn't frozen but yet never comes on, high and low side for freon are within range.
Old Jul 31, 2012 | 07:26 AM
24TEN's Avatar
PHANTOM MENACE
Like any other relay, make sure the switch side has no continuity then apply power to the resistor side. It should make an audible click if it's working, you can verify this by checking for continuity after power has been applied. If no click is heard or there is still no continuity then the relay isn't working.
schueytenten
Sep 11, 2010 03:14 PM
totsie7944
Jun 18, 2009 10:25 PM
beat
Apr 27, 2009 09:16 AM
delta901
Jul 17, 2005 03:15 PM
veggiemaster
Sep 28, 2004 08:56 PM
