Drilling CF hood
I have brand new multi step drill bits and some hood locks would this work properly? the bit gets bigger as you drill deeper and needs to be a pretty big hole (forget the size now)
I would definitely NOT use a hole saw if you can help it. The step drill bit should work fine- just drill slowly and smoothly, and as noman mentioned mask off the area you're drilling through. This should prevent the coating on the CF from cracking/splintering.
EGcivicBoy
11
Nov 18, 2003 05:56 PM
