what block would be better for a turbo build?
Old Jul 30, 2012 | 09:46 AM
akarooster's Avatar
Default what block would be better for a turbo build?
What block would be better for a turbo motor? I have a b16 block now and I have 84.5mm pistons for a b20 block. I wanna know which one would be more reliable to build. I'm going to send it off to have the CSS (cylinder support system) put in it. So would it matter really which block I went with?? Thanks
Old Jul 30, 2012 | 10:04 AM
MonkeyMagic's Avatar
Default Re: what block would be better for a turbo build?
css.. interesting.
well the pistons won't work in the b16 block unless you sleeve it.
b20 block's are known for poor casting and the metal of the factory sleeves will accentuate any tendency to knock.
probably get better responses in the forced induction section.
Old Jul 30, 2012 | 10:35 AM
99electron_blue_si's Avatar
Neither IMO. I'd choose to do the b16 with the correct size pistons if you insist on using one of those two... but you can pick up an LS block/crank for cheap, or a GSR for not much more.
Old Jul 30, 2012 | 10:45 AM
akarooster's Avatar
OK thanks. I'll see if I can get someone around here where I am to see if they have new CP pistons that are 81mm and that will triad for mine. I think that would be a fair deal. Wouldn't you think?
akarooster
Aug 3, 2012 05:41 PM
BrOkEn_Dc2
Apr 9, 2006 03:50 PM
allnapower
Apr 15, 2005 03:54 PM
majek
Oct 14, 2004 02:49 PM
C8V6C
22
Dec 27, 2003 06:45 PM
