ordering rebuild kit
Old Jul 30, 2012 | 07:55 AM
FOKAI95's Avatar
Default ordering rebuild kit
Going to rebuild my D15B7 honda civic shoc does anyone know where to order a whole rebuild kit and ships to GUAM lmk thanks
Old Jul 30, 2012 | 06:19 PM
90civicstdgold's Avatar
Default Re: ordering rebuild kit
OEM Honda or nothing else in this case.
Old Jul 31, 2012 | 03:03 AM
FOKAI95's Avatar
Old Jul 31, 2012 | 03:10 AM
non-VTEC's Avatar
http://www.ebay.ca/itm/Honda-Civic-D...#ht_3529wt_952
you can also inquire about the rings and bearing set....i used this seller before and they are legit...good stuff and good prices.
Old Jul 31, 2012 | 11:58 PM
FOKAI95's Avatar
Thanks so i can just ask to for bearings etc thats not included
Old Aug 1, 2012 | 03:17 AM
non-VTEC's Avatar
ya you would need piston rings and bearings if you are doing a full rebuild.
Old Aug 1, 2012 | 12:07 PM
FOKAI95's Avatar
Alright thanks non-vtech
Old Aug 1, 2012 | 08:19 PM
Julio@Bisimoto's Avatar
It is not recommend just to replace rings on standard sized piston on a rebuild. Factory cylinders wear down over time leaving them out of round which can cause major issues with oil consumption and poor compression.
When doing your rebuild I would recommend going with a .5mm oversized pistons along with bore and hone of your cylinders to have a true round bore for proper ring seal.
Judge Owens
11
Mar 16, 2014 09:54 AM
climb_on
16
Sep 5, 2007 08:49 PM
4EN[sic]
Aug 9, 2007 04:19 AM
carbonfib
May 15, 2007 05:59 PM
wullie_vtech
Jul 6, 2006 10:09 PM
