better for a turbo?
Old Jul 30, 2012 | 06:06 AM
akarooster's Avatar
Default better for a turbo?
Would a b16 block be better for a turbo then a b20 block? Why?
Old Jul 30, 2012 | 06:32 AM
MonkeyMagic's Avatar
Default Re: better for a turbo?
what does "better for a turbo" mean?
Old Jul 30, 2012 | 07:02 AM
akarooster's Avatar
Default Re: better block for a turbo motor?
What block would be better for a turbo motor? I have a b16 block now. But I have 84.5mm pistons for a b20 block. I wanna know which one would be more reliable to build. I'm going to send it off to have the CSS put in it. So would it matter really? Thanks
Old Aug 1, 2012 | 08:34 PM
Julio@Bisimoto's Avatar
If you are going with stock sleeves I would recommend an 81mm block such as your B16 or a B18 with a 81.5mm pistons allowing for additional support. Of course power goals and tuning will come into play with what ever route you choice.
Old Aug 3, 2012 | 05:41 PM
sir 97's Avatar
B16
Stock B16s have seen 300hp while built motors have seen 500+ horsepower
The B20 The only advantage of the B20 over the LS motor is the extra two tenths of a liter displacement. This extra displacement comes at a price however. In order to achieve 2.0 liters of displacement the cylinder sleeves are manufactured at 84mm instead of the 81mm on other B series sleeves. The design of these sleeves varies slightly from other Honda sleeves which accounts for their cracking more easily.
you can check http://www.beesandgoats.com/boostfaq...ml#TurboBasics
darkstarbd
Nov 11, 2013 09:51 PM
akarooster
Jul 30, 2012 10:45 AM
turbo Si
Nov 1, 2005 04:40 AM
jdmcivic1999
Mar 7, 2005 08:10 AM
majek
Oct 14, 2004 02:49 PM
