dpfi vs. mpfi
Old Oct 15, 2002 | 03:52 PM
lazy bum shaughn's Avatar
Default dpfi vs. mpfi
Before anything yes I searched, but didnt find out what exactly things are. To my unerstanding, the CRX DX has DPFI and the HF and SI has MPFI.
What is DPFI and FPFI, and what is the benifit of having MPFI?
Thanks.
Old Oct 15, 2002 | 03:55 PM
88CiViC_DX's Avatar
Default Re: dpfi vs. mpfi (Breakdancer)
Better flow of air. One injector per cylinder instead of 2 in a throttle body. It also responds better to mods than DPFI. Since the DPFI was orignally made for economy.
Old Oct 15, 2002 | 03:57 PM
Aphrodavid's Avatar
switching to MPFI was the best thing i could have done to my motor. if youre contemplating on whether to do it or not, DO IT!!!!!!
Old Oct 15, 2002 | 03:58 PM
Default Re: dpfi vs. mpfi (88CiViC_DX)
Thanks for the quick reply guys. If DPFI is for economy, than why does the CRX DX have it, and not the HF?
Old Oct 15, 2002 | 04:01 PM
Aphrodavid's Avatar
even thou HF is MPFI, the intake manifold/throttle body is like 1/3 the size of an SI. so an HF motor actaully produces less HP than a DX.
Old Oct 15, 2002 | 04:07 PM
Default Re: dpfi vs. mpfi (ZZZZZZZ)
I see, thanks. As you can see I dont have much knowledge on CRX, but I'm learning.
If you want to swap a B-series, or even a SOHC VTEC motor in a DX, you dont need to convert to MPFI do you since you're swaping motors anyway? Or am I wrong?
Old Oct 15, 2002 | 04:09 PM
importfan85's Avatar
All of the engines you might swap in, ZC, b16A, etc., are all MPFI. You will have to do the wiring and such when you swap engines
Old Oct 15, 2002 | 04:10 PM
Aphrodavid's Avatar
yes you do have to convert to MPFI if youre planning on doing any type of swap whether it be sohc vtec or a b series because those motors are all MPFI.
Old Oct 15, 2002 | 04:15 PM
Well if they come with the whole swap, wont they come with the parts needed for MPFI?
Old Oct 15, 2002 | 04:19 PM
slowman's Avatar
I took way too long
usually they will not come with the wiring harness. thats where hondata comes in i think?
Old Oct 15, 2002 | 04:25 PM
Aphrodavid's Avatar
yes, if you get a complete motor, then you will have all the parts for MPFI, but you still have to do the wiring for it
HondaHeddie
Sep 23, 2006 09:58 PM
ineedacrx
Nov 14, 2005 04:38 PM
5litereater
Jun 24, 2004 06:01 PM
omahajim
Jun 15, 2004 12:40 PM
AVXHATCH
Apr 28, 2004 01:55 PM
