98 Civic Door Locks
Old Jul 29, 2012 | 05:06 AM
ChristopherJaso's Avatar
Default 98 Civic Door Locks
So Ive been reading everything i can find about the door locks
i keep reading this the dome light wont work if the stock radio isn't there, well i have a Aftermarket Radio (Pioneer DEH-6400BT) and my dome light still works fine, only thing my power locks never worked (i don't have a key fob)
i still need to check if the actuators are good i think they are but ill check,
i noticed that my stock radio is different.
http://i639.photobucket.com/albums/u...cture_3827.jpg
i have 3 cables 2 wide 1 skinny.
1st wide one radio
2nd wide wasn't plugged in and radio doesn't have a spot
3rd skinny IDK what that does.
can some one explain Please ?
i know i probably have to put my stock radio in my dash or buy a new stock one cause i think i need that other wide plug no ?
Old Jul 29, 2012 | 06:23 AM
Default Re: 98 Civic Door Locks
no its a 5 pin green connector
Old Jul 29, 2012 | 07:56 AM
Former User's Avatar
At the rear of the radio, connector A is for the radio itself whereas connector B is for the keyless lock system.
However, the power lock system does not depend on the keyless lock system. Are you saying that the power locks don't work at all? Give more details.
Old Jul 29, 2012 | 08:19 AM
Yeah, the switch on my drivers door doesn't work at all, apparently it randomly stopped working awhile back.
i wanna have a key-less entry system so im wondering if i should just a get a stock radio that has the plug and put in the back of the dash buy a key fob or buy an aftermarket system and an alarm system ?
Old Jul 29, 2012 | 08:23 AM
i wanna have a keyless entry system so im wondering if i should just a get a stock radio that has the plug and put in the back of the dash buy a key fob or buy an aftermarket system and an alarm system ?
If you want keyless, then you first must get the power locks working. Test the simple stuff first -- the lock fuse 51 and the switch.
Getting a stock radio with keyless or the other options will work. You just need to decide.
Old Jul 29, 2012 | 08:29 AM
fuses are all good i replaced all of them when i got the car.
my radio doesn't have that "B" connector, my second connector is a 5 pin skinny green one,
i can manually lock all the doors, all the fuses are brand new, wires all look fine. ill check with a volt meter tomorrow at work, but i think its either my module or maybe a few of the actuators which isn't to hard to get new. but id like a check list like ("A", "B" and "c" and if they don't work u need "D" )kinda of thing
what should i check to see how to fix it ?
Old Jul 29, 2012 | 08:42 AM
After you replace a fuse, it can blow immediately. Voltage test fuse 51 on both top test tabs.
Don't guess what the problem might be. Do electrical tests to know what the problem actually is.
Old Jul 29, 2012 | 08:52 AM
Ok so check the fuse (i kno thats good ive looked at them after a week and all were good) but ill check if it has power.
check actuators on each door
Check door lock switch on Drivers door
Check module
and replace as needed ?
Old Jul 29, 2012 | 09:03 AM
There's no test for the control unit. If all else test fine, then replace it.
You'll find a diagram for input tests in the FAQs sticky.
teb0613
Jun 26, 2015 10:12 PM
thaigleshmk
Aug 9, 2012 10:01 PM
oaking
Audio / Security / Video
Jul 18, 2005 01:21 PM
acumen
Jan 2, 2005 08:49 PM
switching5
13
May 2, 2004 09:09 PM
