89 ef with 95 ls motor lack of power
Old Jul 28, 2012 | 07:30 PM
timothy88's Avatar
Icon2 89 ef with 95 ls motor lack of power
Hello all I'm a newbie to the site. Wanted to get some opinions on why I'm lacking power in my 89 ef. Just bought the car recently its got a 95 obd1 ls swap with a gsr tranny. It seems to lack power in low rpms as compared to my 92 ls which has almost 300,000 miles on it. It also surges at idle. It had anew distributor on it when i got it, an a (ghetto) wire tuck. Thought maybe it could be a timing issue, but just wanted to get some opinions so that when I get time i can actually try an fix all possible issues. Any help is greatly appreciated an I will listen to all advice.
Old Jul 28, 2012 | 08:12 PM
villc713's Avatar
Default Re: 89 ef with 95 ls motor lack of power
Any check engine lights?
Old Jul 28, 2012 | 08:21 PM
timothy88's Avatar
I've seen it come on once but it went right back off.
Old Jul 29, 2012 | 03:12 PM
timothy88's Avatar
ecu threw a code 43 which I believe is the fuel supply system
Posted from Honda-tech.com App for Android
Old Jul 29, 2012 | 03:16 PM
timothy88's Avatar
also like I said the motor is from a 95 ls but the ecu is a pr4 obd0 ecu. an the intake manifold has a plate covering a hole on the motor side of the mani where a sensor would have went. any idea if that affects anything
Old Jul 29, 2012 | 07:06 PM
villc713's Avatar
Could you post some pics?
Old Jul 29, 2012 | 07:58 PM
timothy88's Avatar
I can in the morning have to figure out how but I will. also the distributor has a wire running out of it an through the firewall not sure where its running to yet bit ill post a pic of that too. an also it has a single wire o2 sensor
Old Jul 29, 2012 | 08:16 PM
villc713's Avatar
It's single wire because it's running a obd0 pr4. Which color wire is it connected to on the dizzy?
Old Jul 29, 2012 | 08:25 PM
timothy88's Avatar
its running to the inside of the dizzy ill take the cap off an check where its running to tomorrow also
Old Jul 29, 2012 | 08:26 PM
timothy88's Avatar
it also has trouble starting, it cranks over about 10 times before it fires up
Old Jul 30, 2012 | 12:57 AM
DCRB's Avatar
do you have an aftermarket tachometer (rpm or rev gauge) installed? that is probably what that single wire is.
the hard starting is most likely a bad main relay, easy to repair or replace.
your belt timing could be off on one cam, causing the lack of power feeling in the low end area.
the plate covering a hole on your intake manifold could be causing a vacuum leak which would make your idle surge, more than likely though your FITV is leaking because it has backed out... assuming you have the matching obd1 intake manifold your FITV (Fast Idle Thermal Valve) will be bolted to the bottom of your Throttle Body. the pix are dead, but this thread says how to fix it. super easy to do:
https://honda-tech.com/forums/tech-misc-15/surging-idle-how-tech-article-56k-beware-1003988/
Old Jul 30, 2012 | 02:51 AM
timothy88's Avatar
ill check all that out an get some pics today thanks for the help ill keep ya posted
Old Jul 30, 2012 | 03:57 AM
timothy88's Avatar
for some reason it won't let me post any attachments
Old Jul 30, 2012 | 10:57 AM
timothy88's Avatar
ok so the intake is an obd0 not an obd1 an I didn't see the fitv under the throttle body.
Old Jul 30, 2012 | 11:02 AM
timothy88's Avatar
when i traded for the car the boy said he had to replace the motor an he used a 95 ls in it I think he just used all the obd0 parts so he didn't have to convert it
Old Jul 30, 2012 | 04:19 PM
timothy88's Avatar
so I think my fpr is to blame for my poor performance can anybody tell me a good aftermarket adjustable fpr for the obd0 ls motor
Old Jul 30, 2012 | 07:19 PM
timothy88's Avatar
ok so I know everybodys probably gettin annoyed with me but I've also noticed that sometimes when I go wot it bogs down like its gonna die then it picks right back up again any idea what that could be. an it seems to be running really rich
Old Jul 30, 2012 | 09:04 PM
villc713's Avatar
Doe you have intake air temperature sensor on there?
Old Aug 1, 2012 | 10:56 AM
timothy88's Avatar
yes it does have one
Old Aug 1, 2012 | 01:43 PM
timothy88's Avatar
ok so I checked all the vacuum lines it doesn't have the evap canister an the vacuum on the fpr is running straight to the manifold could that be the cause of the code 43
Old Aug 1, 2012 | 03:56 PM
timothy88's Avatar
so does anybody know where the vacuum lines should run if the evap can an fuel regulator solenoid were deleted during the wire tuck
Old Aug 2, 2012 | 01:57 AM
DCRB's Avatar
for pics use photo bucket or flikr or something like that.
once you post pics of your intake manifold we can tell you where to run your vacuum lines.
lowliferanger94
Apr 19, 2007 07:47 PM
Doh!
Oct 11, 2004 08:26 PM
SiR831
May 6, 2003 04:36 PM
