K20A2 or B18C Type R
Old Jul 28, 2012 | 02:28 PM
tippatone's Avatar
Default K20A2 or B18C Type R
Whats going on HT?? I'm thinking of getting a 1999 SI Shell in the very near future.....I am having a problem making a choice of a motor to put in.....I have two options......A K20a2 from a dude on another fourm....or a JDM B18C Type R 97-98 spec from JDM Engine Corp..... I just can make a decision......has anybody out there had the same choice to make??? Thank you in advance......
Old Jul 28, 2012 | 02:50 PM
doood's Avatar
been there done that
Default Re: K20A2 or B18C Type R
They are two very different engines. Can you afford all the little odds and ends for a k swap? A b18 pretty much drops right in.
Old Jul 28, 2012 | 03:01 PM
tippatone's Avatar
That was one of the issues that came up....exactly what odds and ends we talking? And what will it cost?
Old Jul 28, 2012 | 03:43 PM
94_civic_dx's Avatar
Wat are u Paying for the engines..k-swap in a civic is nasty but somewhat pricey
Old Jul 28, 2012 | 03:58 PM
Lambo123's Avatar
How much are you willing to spend and what are your goals with the car let's start with that. If it's just k20a2 vs. B18c5 then k20 all the way.
Old Jul 28, 2012 | 05:45 PM
tippatone's Avatar
K20: 3300 shipped........type r.......3500-3700 shipped......but i know i will need kpro and that is about a 1000 right??
Old Jul 28, 2012 | 05:49 PM
tippatone's Avatar
I just want to get 220 hp out of it.....i know the k will give me that stock...but to get it in the civic is gonna cost......the b18c5 gives me about 200 but im sure I can gain 20 hp with some bolt ons im sure.....
ss_zoidberg's Avatar
Mounts, cables, shifter, harness. And yupp maybe less if you find a gently used one
Old Jul 28, 2012 | 06:31 PM
tippatone's Avatar
Yeah....i think im going to keep it B series.....just get some hasport mounts and drop and drive
Old Jul 28, 2012 | 08:23 PM
redlinexd's Avatar
or Boosted Ls or GSR swap.
Old Jul 28, 2012 | 10:27 PM
killudie123's Avatar
i have a b18c5 in my 99 em1. love it all the way, i didnt do the swap but it is really reliable and pretty fast. i baby mine alot it all depends on you, my bro got a k20a2 swap in his car and it ended up being expensive but he was pleased with the car and it really pulls!
Old Jul 29, 2012 | 03:03 AM
tippatone's Avatar
Yea I think Im going with the type r....the kpro alone is enough to back me out of going k
Old Jul 29, 2012 | 08:59 AM
blazindominican's Avatar
Can i make a suggestion? you should look into an H2B set up...they have proven to produce as much power as the infamous k series and its probably the same price as your type r swap will cost. the H motor itself is very cheap and the only thing that will cost extra will be the actual H2B adapter plate. everyhting else is the exact same...you get an H series long block and EVERYTHING else is b series.
Old Jul 29, 2012 | 09:50 AM
tippatone's Avatar
Nice.....thats a good idea.....the torque of the h motor with the b tranny.....how much does the H2B plate cost and where do i get it from? I would use the B mounts right? How much HP can expect to see from this setup?
Old Jul 30, 2012 | 04:24 AM
Theres about two or three companies that make the H2b kit. I personally have the evolution kit. Yes you use b series mounts. You can probably get in the low 200s hp..from stock...once u start upgrading your air, exhaust, fuel, computer chip, intake manifold, cams maybe...you can get in the mid to upper 200 ..and all this before ever doing internals or even turbo
Old Jul 30, 2012 | 02:17 PM
tippatone's Avatar
Thanks......I was doing research and that might be a cheaper route.....what u got ur H2B in?
Old Aug 6, 2012 | 06:34 AM
I got it ina Del sol
Old Aug 8, 2012 | 08:47 PM
CRacer21's Avatar
Saves $800 bucks.
http://www.hybrid-racing.com/product...ilizer-delete/
rickkane
Jul 30, 2008 10:43 PM
nihad
Mar 4, 2007 03:24 PM
BLK99VTECR
Jun 24, 2003 10:06 PM
