A/C system not working properly. Help.
Old Jul 28, 2012 | 02:27 PM
jjrek9's Avatar
Icon6 A/C system not working properly. Help.
Vehicle: 1997 civic dx. Stock.
I had the A/C system professionally charged a few months ago and now that the weather has gotten warmer I was going to use it. When I turn the A/C on the condenser fan comes on however I only get hot air from the vents. I noticed that the A/C compressor clutch is not engaging. Now I have taken it to be checked by two shops but I am getting conflicting results. One shop said to replace A/C compressor, the other said to replace A/C condenser. I am not very knowledgeable when it comes to A/C system repair so my question is, does the A/C compressor clutch come on only when the system is charged? Or should it be engaging regardless? Any other things that I should be looking into?
Thanks in advance.
Old Jul 28, 2012 | 02:38 PM
Former User's Avatar
Default Re: A/C system not working properly. Help.
Originally Posted by jjrek9
...my question is, does the A/C compressor clutch come on only when the system is charged? Or should it be engaging regardless?
The clutch won't engage if the system has leaked out all of the refrigerant.
Did any shops check whether the system is empty?
Old Jul 28, 2012 | 03:38 PM
jjrek9's Avatar
yes, the shop that said to replace the condenser said it had leaked out.
Old Jul 28, 2012 | 03:45 PM
If the condenser has a hole in it, then it definitely needs to be replaced. When done, replace the receiver/dryer, evacuate the system, and then check whether the vacuum holds overnight (=no leaks). Then add oil and recharge the system.
Old Jul 31, 2012 | 06:10 PM
jjrek9's Avatar
How is this done? How does one check to see whether the vacuum holds? Like I said I am not very knowledgeable when it comes to A/C systems. Thanks for the help by the way.
Old Jul 31, 2012 | 07:00 PM
redm3turbo's Avatar
you can have it filled with dye....to check for the leaks. if no leaks show up under the black light, have it charged up, and enjoy the a/c again.
dons2277
Jul 26, 2012 07:06 AM
GaHonda
Jun 8, 2011 05:32 PM
CLE
10
Aug 14, 2006 09:05 PM
Boostage
Jul 24, 2006 09:25 AM
maivla01
Jun 8, 2006 08:06 PM
