no boost turbo b16.
Old Jul 28, 2012 | 01:02 PM
shizkabob3421's Avatar
Default no boost turbo b16.
hello i have b16 that i just turbocharged..and when the wastegate is hooked up it does not make any boost.But when you unhook the line from the wastegate it works..any ideas?
line setup goes from turbo housing to wastegate.
Old Jul 28, 2012 | 06:50 PM
crvtectim's Avatar
Default Re: no boost turbo b16.
To which port on the wastegate?
Old Jul 28, 2012 | 07:05 PM
oscalito's Avatar
Icon4 Re: no boost turbo b16.
hey i have a typeR tubo and in the wastegate theres two line thing that u can put the hose for the boost if ur is in the rong one it wont work so tried to put it in the right side bicause if u said that u on hooked the hose and it boost than it has to be that
Old Jul 28, 2012 | 07:50 PM
i have it on the bottem port on the tial wastegate.
Old Jul 28, 2012 | 10:25 PM
turbohatch96y7's Avatar
WTF?
Old Jul 29, 2012 | 01:55 PM
any ideas?
Old Jul 29, 2012 | 01:58 PM
TheShodan's Avatar
Moderator
Where is the other end going to? what vacuum source? is it "T'd" off to anything else?
Old Jul 29, 2012 | 02:50 PM
no it runs straight from the compressor housing to the wastegate.
Old Jul 29, 2012 | 03:28 PM
TheShodan's Avatar
Moderator
On the end, toward the compressor housing outlet? May be TOO strong a source. Is the line collapsing?
Old Jul 29, 2012 | 04:08 PM
Old Jul 29, 2012 | 04:09 PM
that's how it's ran..i will try and hook it somewere else,and see if it works.
Old Jul 29, 2012 | 06:00 PM
rclark's Avatar
lol, no fire ring?
Old Jul 29, 2012 | 07:09 PM
oscalito's Avatar
well check if is not bend on the butom maybe ur hose are old
Old Jul 29, 2012 | 07:10 PM
oscalito's Avatar
it cut be bend check if is not
Old Jul 29, 2012 | 07:13 PM
oscalito's Avatar
if is not the hose then is ur wastegate not good
Old Jul 29, 2012 | 10:43 PM
Originally Posted by rclark
lol, no fire ring?
yes it has a fire ring.
Old Jul 29, 2012 | 10:44 PM
and the hoses are brand new.
Old Jul 30, 2012 | 06:12 AM
jdmhondak9's Avatar
but where do you have the line running from the wg ? you could have neg vacume
Old Jul 30, 2012 | 09:01 AM
it runs to the compressor housing..and your supposed to have pressure, not a vacuum source that's what ive read.
Old Jul 30, 2012 | 09:22 AM
jdmhondak9's Avatar
i have mine running to the IM, the IM creates vacuum. Yes if its connected to the compressor housing its pressure ha, but that could be your problem right there.
Old Jul 30, 2012 | 10:56 AM
ok ill try it..and let you know.
Old Jul 30, 2012 | 07:41 PM
i ran a line from the manifold..it made 1 psi of boost instead of 0 psi.
Old Jul 30, 2012 | 09:07 PM
EsotericImage's Avatar
Retired Moderator
WG might be needing a rebuild
Old Jul 30, 2012 | 09:49 PM
Hidenplanvew's Avatar
Dude just stop.. Maybe you should go back to school, or just stop you have the most general comments. You are giving no help too..
Old Jul 31, 2012 | 06:52 AM
kyden's Avatar
i would take the wastegate apart and check for tears in the diaphragm. i also hope you have a dump tube on that.
the way you have the line routed is fine.
