Swapping a Bseries in a 94 VX?
Take your VX harness and plug it up to the B16 engine. There will be plugs left over that don't go anywhere so don't worry about it. Run one wire from the knock sensor to the ECU and run 4 new wires from the 4-wire O2 direct to the ecu.
Don't forget you'll also need a new b-series fuel line, throttle cable, and upper and lower radiatior hoses. I used the hoses and fuel line from a 99-00 Si and the cable from a 90 integra.
lowntegra
May 25, 2007 06:57 AM
tnsxsear1
Aug 20, 2004 09:48 PM
