FS: Oakley Sunglasses
THESE ARE REAL!
Price:$60 -- PRICE REDUCED
I've seen some weird **** posted on here, I feel like it's worth a shot.
Pictures are after the description below.
These glasses were worn for maybe 10 minutes. I don't care for them too much so I'd like to just sell them. THEY ARE POLARIZED! Polarization was extra, glasses retail alone for $100.
It comes with the carrying case as well as the original box it came with. Since I took them off they've just been sitting in their carrying case in the original box.
Description from Oakley:
Oakley Ten® is the classic Oakley look, amped with volume and rigged with tech. You’ll have sculpturally integrated hinges with dual cam action, a comfortable Three-Point Fit, and the optical performance you need for a life with momentum.
Oakley Ten uses XYZ Optics® (a benefit of High Definition Optics® (HDO®)) to keep your vision razor sharp at every angle of view, even with 8.75 base lens curvature. That’s what Ten offers, and it means you’ll have a wide peripheral view with extra coverage to block annoying things like side glare, wind, and the type of impact that can ruin your outlook. Even with all that curvature, you’ll have optical precision that meets ANSI Z87.1 standards, and same goes for impact protection because the comfortably lightweight O Matter® frame is beyond durable.
All our sunglass lenses are made of pure Plutonite® to block every ray of UV, and the lens curvature of Ten helps prevent light from sneaking around the sides. If you want optimal performance, go with Oakley HDPolarized lenses. They block 99% of reflected glare without the haze and visual distortion that comes with polarized lenses made with inferior methods.
Frame:
Durability and all-day comfort of lightweight, stress-resistant O Matter® frame material
Precision and durability of sculpturally integrated hinge mechanisms with dual cam action
Optimized peripheral vision and side protection of 8.75 base lens curvature
Comfort and Performance of Three-Point Fit that holds lenses in precise optical alignment
Metal icon accents
Lens:
Oakley HD Polarized – Minimized glare via technology that produces the best polarized lenses on the planet with greater than 99% polarized efficiency (optional)
Optical precision and performance that meets ANSI Z87.1 standards
Impact resistance that meets ANSI Z87.1 standards for high-mass and high-velocity impact
UV protection of Plutonite® lens material that filters out 100% of UVA/ UVB/ UVC & harmful blue light up to 400nm
Frame:
Metal icon accents
Lens:
Ek9hatchback
Texas -OK -LA (Sales)
May 7, 2010 09:09 PM
RCautoworks
Jan 24, 2007 07:49 PM
