coupe front on a del sol
Old Jul 28, 2012 | 08:22 AM
redturbo0's Avatar
Default coupe front on a del sol
How hard is it to do? I'm looking into maybe buying myself a del sol and doing this. Does it just bolt on?
Old Jul 28, 2012 | 09:25 AM
gzes's Avatar
Default Re: coupe front on a del sol
You need to cut n weld both fenders, you need to take off radiator core support off the delsol and weld the new one in correctly, you need the headlight and basically if you dont cut n weld rigbt it will not line up. My sol has the conversion and it looks like it was done by a pro and still the lines are alittle weird on the hood to winshield area....
Old Jul 28, 2012 | 10:47 PM
mr darcko's Avatar
pretty easy, my friend just bought one with it already done, but we put it back to stock. rad support was bolted not welded, and you have to cut the civic parts to fit. if you have a nack or know somebody with some skills you're good to go.
Old Jul 29, 2012 | 04:16 AM
gzes's Avatar
The correct way is to weld on. Whoever bolted it was too lazy to weld it. If yall didnt weld the original then go do it because its welded on for a reason
Old Jul 29, 2012 | 09:49 AM
nealnanoHX's Avatar
Do a search it has been done before. It is not very hard if you know how to do basic body work and auto repair you should be able to get it all done no problem. I love the way a Del Sol looks with a 92-95 Civic front end.
Perkul8r
Jun 1, 2009 10:11 PM
X-Psico
34
Jan 26, 2008 08:14 AM
jdmcivicsi7
Dec 19, 2005 02:25 AM
homeskillet
Dec 14, 2004 07:49 PM
b18c1delsol94
31
Mar 20, 2004 02:47 PM
