1994 Accord Vtech Starting Issues
Old Jul 27, 2012 | 08:57 PM
achornesjr's Avatar
Icon6 1994 Accord Vtech Starting Issues
Hey I was wondering if anyone can help me figure out why my Honda wont start. It was working fine before I got a flat tire on the side of the road but it did start after the tire went flat because we more it off the road. So the issue is it turns over but wont crank. Someone said the timing is off I doubt its my timing belt. I changed the distributor no luck. And I was told it wasnt the fuel pump so what are some other things i can check? It cranks strong but just wont turn over.
Any help please?
Old Jul 28, 2012 | 01:41 AM
doctorbee's Avatar
Default Re: 1994 Accord Vtech Starting Issues
check for spark and fuel pressure at the fuel rail.
your engine needs 1.air 2. spark 3. gas to run
Old Jul 28, 2012 | 08:03 AM
achornesjr's Avatar
How do i check the fuel rail?
Old Jul 28, 2012 | 06:48 PM
BRADY-CD7's Avatar
there is a pressure relief service bolt (banjo bolt) on the drivers side of the fuel rail... loosen that and you will know if you are getting gas... !MAKE SURE TO PUT A RAG OVER THE BOLT BEFORE YOU LOOSEN, OR YOU MAY GET SPRAYED!
91da_teg
Jan 21, 2009 11:16 PM
dc2doi
Jan 6, 2008 01:43 PM
C_H_A_D
Aug 28, 2006 05:09 PM
turbocivic0618
Nov 24, 2005 08:20 AM
tnord
22
Sep 26, 2003 08:45 PM
